Austin 1300Gt Engine
10 replies to this topic
#1 josh.goddard
josh.goddard
  • 398 posts
  • Local Club: Derbyshire Classic Mini Club
Posted 08 June 2012 - 04:46 PM
hi
i have an engine out of an austin 1300gt can anybody shed any light on the spec on one of these engines and do they have a cooper s crank in them if so can anybody tell me the spec of the crank.
Thanks josh
#2 clivemk1mini
clivemk1mini
  • 1,064 posts
Posted 08 June 2012 - 05:05 PM
I have one and was told there basically a 1275 gt engine but I could have been miss informed
#3 josh.goddard
josh.goddard
  • 398 posts
Posted 08 June 2012 - 05:23 PM
i am actually going to be using it to build a 1340 turbo which i hope to get 200 bhp from but my engine builder has said i need to be using a cooper s crank and need to know weather its the same as the one in my engine
#4 James_1
James_1
  • 253 posts
Posted 08 June 2012 - 05:32 PM
The 1300GT is not the same as a Cooper S engine. It does have an 11 stud head/block but the crank is not the same. It uses the larger big ends and isn't EN40. The head is S spec though and the conrods are better than standard. As is the crank.
#5 josh.goddard
josh.goddard
  • 398 posts
Posted 08 June 2012 - 06:08 PM
do you know the stroke of the crank at all ?
#6 bmcecosse
bmcecosse
  • 9,699 posts
Posted 08 June 2012 - 07:45 PM
Standard 1275 stroke. The crank is not anything special - it does not have the S head, but it does have the large inlet valve 940 head. It will not be strong enough for a turbo.....that's why they developed the turbo engine - with the better main bearings......
#7 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 08 June 2012 - 10:53 PM
The cylinder head is exactly he same as a late Mk 2 or Mk 3 Cooper S.
#8 James_1
James_1
  • 253 posts
Posted 09 June 2012 - 03:38 AM
And a standard crankshaft after the first few hundred...
#9 oltonlad
oltonlad
  • 2,401 posts
Posted 09 June 2012 - 07:37 AM
the very first MG metro turbo engines used a different type of crank bearing which was soon disregarded because austin rover had major issues with them failing, many early metro turbo's were returned to main dealerships under warranty with "knocking cranks", it cost austin rover a fortune to sort it out!
i very nearly purchased a 3 year old (28,000 mile) MG metro turbo from evans halshaw back in 1986, the car was mint and my favourite colour (black), but when the salesman started it up from cold the crank rattled badly so i told him that the engine was ********d and i didn't buy it.
Edited by oltonlad, 09 June 2012 - 07:43 AM.
#10 Ethel
  • 26,022 posts
Posted 09 June 2012 - 11:49 AM
It is pretty much the same as the very last Mk3 S / very first 1275GT's. The shorter diff made them popular for sticking in Minis back in the day.
I'd be more worried by the age than the spec for turboing, but any late A+ would be a better option.
It was the production of the crank journals, not the bearings, that let down the early A+'s.
#11 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 10 June 2012 - 05:09 PM
This should help;
You should have a tufrided crank in that engine with the bigger journals.
Cooper S variants
970cc
9F/Sa/X Engine numbers 29001-29003 with Tecalamit filter
9FD/Sa/X Closed circuit breathing introduced with Tecalamit filter
9FE/Sa/X Closed circuit breathing, oil filter with oil light switch introduced
9F/Sa/X Engine numbers 29039-30029 Purolator oil filter with oil light switch and closed
circuit breathing
1070cc
9F/Sa/H Engine numbers 26501 to 33660 and 19201 to 20410
9FD/Sa/H Engine numbers 33661 to 33948 with closed circuit breathing and oil light switch in
oil filter head
1275cc
9F/Sa/Y Engine numbers 31001 to 31504 pre closed circuit breathing with Purolator oil filter
9FD/Sa/Y Closed circuit breathing with oil light switch on filter housing after engine number
32178
9FE/Sa/Y Closed circuit breathing with oil light switch on Purolator filter housing and piston
design change
9F/Sa/Y From engine number 32378 onwards, cosed circuit breathing with Purolator filter
with oil light switch, Aeg510 camshaft introduced at engine number 40006, cross-
drilled EN40Bcrank at engine number 42730 and metal dipstick tube at engine
number 42548 onwards
12H397 Cooper S Mk3 with dynamo, negative earth and Tuiftrided EN16T crankshaft
12H398 Cooper S Mk3 with alternator, negative earth and Tuftrided EN16T crankshaft
Note: Only Cooper S engines with prefix '9F' had EN40B forged steel, nitrided crankshafts. All other A-series engines had EN16T steel crankshafts which were only Tuftrided on Mk3 'S' and Austin 1300GT (ADO16) and were stamped 12G1683.
1275cc, Solid wall block (no tappet chest covers)
12G/Ta/H ADO17 shape Wolseley, Riley, MG & Vanden Plas fitted with S rods
12H379 1275GT with dynamo, negative earth, electric fuel pump and remote type gearbox
12H380 1275GT with alternator, negative earth, electric fuel pump and remote type gearbox
12H389 1275GT with dynamo, negative earth, mechanical fuel pump and remote type gearbox
12H390 1275GT with alternator, negative earth, mechanical fuel pump and remote type gearbox
12H706 1275GT with alternator, negative earth, mechanical fuel pump and rod changegearbox
12H397 Cooper S Mk3 with dynamo and negative earth
12H398 Cooper S Mk3 with alternator and negative earth
12H/-/ 1275 Austin ADO16 & Allegro
12H610/635 Innocenti Mini with duplex cam drive gears and 11-stud head
12H719/832 Innocenti Mini with simplex cam drive gears and 11-stud head
Edited by mk3 Cooper S, 10 June 2012 - 05:10 PM.
