Why Wont My Clutch Bleed?
12 replies to this topic
#1 jamesy
jamesy
  • 210 posts
Posted 08 June 2012 - 06:51 PM
Cant get the F***in thing to bleed! Took it apart and swapped the slave cylinder for one that i think is working. it aint seized and the old one definitly was.
Anyway, took out the master cylinder, emptied it of all old fluid and refilled it with some lovely new morris hydraulic oil.
now i cant get it to bleed, it seems like instead of sucking fluid in to the cylinder it doesnt....
Clutch down wedge bit of wood between it and seat - open bleed screw, *small puff of air and bubbles* - close bleed screw. - Raise and depress clutch pedal - open bleed screw *NOTHING*
Whats going on?
#2 Andrew O
Andrew O
    Previously known as Andrewo330.
  • 1,425 posts
Posted 08 June 2012 - 06:54 PM
It sounds like a nackered slave cylinder.
Get your self a new one. They're only about £15
Andrew
#3 jamesy
jamesy
  • 210 posts
Posted 08 June 2012 - 07:03 PM
It did wok a year ago when it was on my other mini, its still springy, or are there internal seals?
#4 Andrew O
Andrew O
  • 1,425 posts
Posted 08 June 2012 - 07:08 PM
Yes there are internal seals.
Just buy a new one, it should work then
Andrew
#5 bmcecosse
bmcecosse
  • 9,699 posts
Posted 08 June 2012 - 07:42 PM
Put a tube on the bleeder - and run it into a jar with some brake fluid (NOT 'hydraulic fluid ??!!) in it - then pump away fast down/slow up. It should clear..........
#6 jamesy
jamesy
  • 210 posts
Posted 08 June 2012 - 07:48 PM
Should you use brake fluid in the clutch? its not just ordinary tractor hydraulic oil, cant rmember what its called, but its basicly really runny hydraulic oil.
I was told that the jar method doesnt work, there needs to be a non return setup of some sort, either closing the bleed screw or a non return valve.
#7 bmcecosse
bmcecosse
  • 9,699 posts
Posted 08 June 2012 - 07:50 PM
Well if you put in hydraulic oil - that's all the seals ruined in the master and slave now........ it is all designed for brake fluid. The flexi pipe will need to be changed too......
#8 Spitz
Spitz
  • 1,716 posts
Posted 08 June 2012 - 08:43 PM
Can't you have someone give you a hand? ( edit: foot..lol )
Much easier with two people if you don't have a fancy dancy bleeder.
May take several pump, hold, open, close, release cycles to get all air out.
( Hydraulic fluid ?? )
Edited by Spitz, 08 June 2012 - 08:44 PM.
#9 jamesy
jamesy
  • 210 posts
Posted 08 June 2012 - 09:24 PM
Ok, my bad, I AM WRONG.
will get the overhaul kits ordered. Lesson learned, all part of the mega learning cure that this mini is turning out to be!
#10 tiger99
tiger99
  • 8,584 posts
Posted 09 June 2012 - 12:43 PM
Mineral oil based bydraulic fluid will indeed ruin the seals and hoses. Even a trace of it is bad, so you should renew the rigid pipe too, as you will never get rid of the contamination.
But seal failure takes a day or two to happen. If it would not bleed immediately after filling, it is likely that the pedal is not returning fully, so the piston does not uncover the reservoir port, so no fresh fluid can enter the system. The pedal operation may need to be checked, and the master cylinder may need a shim under it.
Please read the relevant part of the Haynes manual very carefully before doing any maintenance. If that had been the brakes, you could have killed people, as with mineral fluid in the system, total brake failure within a few days is inevitable.
#11 Stella87
Stella87
  • 151 posts
Posted 11 June 2012 - 08:43 PM
Don't want to put a dampener on things but in my Haynes manual, under "Clutch Hydraulic System - Bleeding" it says to use "a tin of the specified hydraulic fluid" in the jar...is this bleeding a different system to the one you guys are on about?
My clutch needs bleeding and I dont fancy replacing the master and slave cylinder! Help is appreciated..
#12 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 12 June 2012 - 06:33 AM
And then in section 0.16 - lubricants and fluids, it specifies for the clutch - Dot4 brake and clutch fluild...
#13 jelboy89
jelboy89
    Formally known as jr4sr4eva
  • 169 posts
Posted 12 June 2012 - 10:01 AM
Just put a braided hose on my clutch with new cylinder. Couldn't get fluid to bottom. Found if you open the bleed nipple and pump away until fluid comes out then bleed as normal all will be fine
