Sealey Spot Welder Problems :/
8 replies to this topic
#1 Austinminimark
Austinminimark
  • 260 posts
  • Local Club: redditch
Posted 09 June 2012 - 05:41 PM
Recently got ahold of a sealy Spot welder. Its Only been used 4 times but its been sat in a garage for years.
Ive used one many times before and never had a problem.
I re filed the electrodes as they were rather flat.
A few spot welds worked fine but now every spot weld i do blows through and it sticks. Ive tryed adjusting the electrodes as ud think i would so it isnt pinching too much and even loosened off soo much, that it wouldnt even weld. Then i tryed holding it on for less that didnt work. Seems like soon as the electrodes touch they stick. Is there away of setting the power or something or something im doing wrong i had to stop and try on other bits of metal and can only get 1 in 10 goes to get even close to working properly. :/ can anyone help?
Mark.
#2 Sam Walters
Sam Walters
  • 2,765 posts
Posted 09 June 2012 - 06:08 PM
I would think about the cross sectional area of the electrodes, have they been thinned down too much? Try filing them back and see if the bigger area sorts out your problem.
#3 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 09 June 2012 - 06:28 PM
you need really clean bare metal surfaces. the good welders have a timer which u can adjust to avoid blowing through or holding on too long.
#4 Austinminimark
Austinminimark
  • 260 posts
Posted 09 June 2012 - 07:55 PM
Yeh all the metal is clean on all sides. It not an electric one unfortunatly. Yeh i thought it was too narrow thats why i also filed them wider but its still happening. :/ ????
#5 Austinminimark
Austinminimark
  • 260 posts
Posted 09 June 2012 - 07:56 PM
I ment it doesnt have a timer*
#6 Austinminimark
Austinminimark
  • 260 posts
Posted 09 June 2012 - 07:58 PM
#7 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,145 posts
  • Name: Sean
Posted 09 June 2012 - 08:00 PM
The ends of the electrodes aren't flat, they should have bevelled edges.
You can get proper electrode cutters for the job.
#8 Shifty
Shifty
  • 13,145 posts
  • Name: Sean
Posted 09 June 2012 - 08:06 PM
Like this..
http://www.ebay.co.u...#ht_1151wt_1270
This can be found cheaper elsewhere though, I think I paid £25 for mine.
#9 Austinminimark
Austinminimark
  • 260 posts
Posted 09 June 2012 - 10:12 PM
Yeh i bevelled the edges and done everything the same as on the other spot welder i used before :/ guna try cleaning all the elctrodes and stuff.ill let you what happens 2morrow. Thanks
