Replacing Bump Stops?
6 replies to this topic
#1 rosstolley
rosstolley
  • 111 posts
Posted 09 June 2012 - 07:09 PM
Hi,
Was fitting new bearings, ball joints and the like. While under the arch I barely touched it and the bump stop fell off! Little bugger...
Is this easily replaced or is it a case of removing the top arm and dropping out the hi-lo?
Cheers,
Ross
#2 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 09 June 2012 - 07:26 PM
easy to replace just jack up the hub so the top arm lifts up enough to allow you to slip it in position. i always use new screws though.
#3 tiger99
tiger99
  • 8,584 posts
Posted 09 June 2012 - 07:39 PM
That is the rebound stop, if you lift the arm to get at it. The bump stop is the pointy rubber thing above the arm. They are both essential.
I only point that out in case you ask for, and get, the wrong part.
#4 rosstolley
rosstolley
  • 111 posts
Posted 09 June 2012 - 08:26 PM
Thats the blighter above the top arm. Can i pop the nut on and off the back of it without emoting lots of bits or will it be a mini adventure? :proud:
#5 Andrew O
Andrew O
    Previously known as Andrewo330.
  • 1,425 posts
Posted 09 June 2012 - 08:32 PM
I have recently done this on my project.
It is very fidily but you can get a spanner behind there to undo it.
If not you can just drill out the old one ( Very easy ) and pop the new one in with a spring washer.
Andrew
Edited by Andrewo330, 09 June 2012 - 08:32 PM.
#6 rosstolley
rosstolley
  • 111 posts
Posted 09 June 2012 - 08:34 PM
Thanks Andrew. I'll save up some money for the swear box then and give it a go.
Cheers,
Ross
#7 Andrew O
Andrew O
  • 1,425 posts
Posted 09 June 2012 - 08:36 PM
Good luck.
Take a look at the early pages of my project thread and me doing mine is there somewhere.
Andrew
