Spax Coilover Vs Minitastic+Gaz
Posted 10 June 2012 - 02:39 AM
Has anyone done a direct comparison or from personal experience? They cost almost the same. Most I read are just general stuff, coilover = track, cones=daily/track, coil=mixed reviews.
Do the coilovers really need reinforcement? Anyone sell the lower bracket (from what I read, the ones that come with the kits, hits the subrframe)
Which would be best? This is for a daily driver. Don't want cones.
Posted 10 June 2012 - 08:05 AM
Posted 10 June 2012 - 08:19 AM
Posted 10 June 2012 - 09:51 AM
Good to know Spax actually rides smoother than stock, everything I read about em was that they rode harsh.
Posted 10 June 2012 - 10:01 AM
http://www.plminisho..._Kit_(Fast_Road)_With_Hi-Lows.html
What do you think you will go with?
Cheers,
Ross
Posted 10 June 2012 - 11:29 AM
Coil overs are not great for the road and take away from the mini feel that we all love. The best option I have seen is mini spares red spot cones and better dampers. Harder better cones but still that great mini feel.
Posted 10 June 2012 - 02:07 PM
Glad you've raised this question pal as its something I've been thinking about also after seeing slightly cheaper versions on PLmini and Huddersfield Spares.
From what I've been reading from the past few days, I'd only go with minitastic+their hilos. But if your not gona use hilos, I guess any would do. Something with regular hilo's being the wrong size, causing the spring to dislodge (but contradicted: read below).
I have done a lot of research into this and have basically found that if you want to lower the car then don't go for the minitastic springs as they can dislodge easily.
I thought the other coils (minisport/minispares) with regular hilos were the ones that dislodged?
Could you please expound on the coilover removing the "mini feel"?
Cones I want to avoid, mostly because they're a wear item, that costs the same as something more permantent.
I'm kinda leaning towards coilovers but the need to fabricate a lower bracket to go low is ehhhhh (my welding skills, don't feel like a skill)
Posted 10 June 2012 - 02:17 PM
Posted 10 June 2012 - 02:40 PM
How low do they go with hilos?
Posted 10 June 2012 - 02:41 PM
A for the coil overs, you're changing what it was that made a mini so different to other cars, the cone suspension was the design and as such putting coil overs on takes that away. It is hard to explain in terms of facts without being in both but even down to the location of compression changing is going to make a difference.
As the coil overs are in a different location, the suspension geometry has been massively changed leading to a different feeling car. It's not the same as putting coil overs on a modern car at all.
Posted 10 June 2012 - 03:07 PM
Let's say I do decide on getting cones. Which would be best? I think Minispares sell ones made from orig tooling, but doesn't say if they're made from the same rubber/manufacturer? Or would the red dots be better, don't plan on using it on trackdays, maybe once or twice I guess, but I do drive spritedly. And I do plan to go low. More concerned on durability, as this is gona be my dailydriver.
Hilo's - Cast (orig?) vs Machined (half price) - Minispares description says the only diff is additional road noise? - Are the orig hilos worth double the cost? - concerned with daily driver friendlines.
Shocks? Spax (adj) vs Gaz (adj) vs KYB (non-adj; this is the brand I use on JAP cars, they seem to last forever) - looking for durability and lowered friendliness.
edit: MiniSport claims they have genuine cones made by Avon. So which has genuine cones MiniSpares or MiniSport or they're both selling the same exact thing.
Edited by ricekikr, 10 June 2012 - 03:12 PM.
Posted 10 June 2012 - 03:35 PM
As for the shocks, I would go for some adjustables but I can't give an informed recommendation on which ones.
Posted 11 June 2012 - 12:18 AM
Posted 11 June 2012 - 06:42 AM
