Engine shudder
9 replies to this topic
#1 zulujumper
zulujumper
    Starting My Mini Up
  • 3 posts
Posted 03 December 2003 - 11:25 AM
I live over here in Germany and bought a 1984 Mini Rover with a 998A engine last year, and have recently encountered a problem that I need help with! When driving from a dead stop, accelerating, my mini will not accelerate smoothly. It shudders, hesitates, and is generally a pill. It will idle fine and rev up with no hesitation. I can change gears with no problem. Spark plugs are new, still waiting on the wires, distributor cap, condensor (parts are hard to come by easily in Germany). I checked the fuel pump, no problem there. My next step was going to be the carbuerator, HS4 type. Any suggestions, has anyone encountered this before and has a solution for me? Thanks!
#2 Wil_h
Wil_h
  • 3,244 posts
Posted 04 December 2003 - 08:34 AM
Have you checked the oil in the dashpot of the carb? if it's low it might cause something similar to what you describe.
It's probably worth getting the dashpot off and giving it a good clean with an aerosol carb cleaner too.
Hope this helps.
#3 zulujumper
zulujumper
    Starting My Mini Up
  • 3 posts
Posted 04 December 2003 - 01:20 PM
Hope this helps.
Funny thing you should mention the dashpot. When this started happening, I noticed that the dashpot damper was loose and unscrewed. I figured this could not be good, so I put it back in and tightened it up, then checked the level and added some oil (13mm above the top of the damper according to my Haynes manual). Anyway, it has not gotten better, so I hope the carb and damper did not get screwed up by me driving with a loose damper! If it sounds like something is broken, please let me know! Thanks!
I will take the damper off tomorrow and give it a good cleaning, thank you!
#4 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
  • Local Club: Blacktop Bombers
Posted 04 December 2003 - 04:01 PM
Hello mate, probly find it's your coil breaking down, or a bad lead...
#5 zulujumper
zulujumper
    Starting My Mini Up
  • 3 posts
Posted 06 December 2003 - 07:56 PM
I figured it out... It was the distributor. I put in new points, a cap and rotor arm, and all is good! Thank you for the help!
#6 Sutty01
Sutty01
  • 603 posts
Posted 24 December 2003 - 11:00 AM
good,glad you fixed it
#7 marksmini's better half
    Marksminis Wifey
  • 1,172 posts
Posted 24 December 2003 - 03:53 PM
glad you got it sorted out
and thank you for leting us no,
cheers
any other you come across, let us no.
cheer's
#8 tom555
tom555
    Mad B***tard
  • 52 posts
Posted 03 January 2004 - 11:47 AM
Hey sutty01's mini does that me and him think its because the rubbers have gone in the steadies.
#9 Sutty01
Sutty01
  • 603 posts
Posted 03 January 2004 - 01:01 PM
TOM THERE ARE NO STEDYS ON :s AND IT UNTUNED
#10 tom555
tom555
    Mad B***tard
  • 52 posts
Posted 04 January 2004 - 12:01 PM
u dum ass i aint suprised u int screwed sumat on it because u have been driving it without an air fillter :) because you will have loads of C**p in your head now witch will increase the engine wear at lot,with half the correct oil in it,NO water in the rad when we got to yours n got unders the bonet it was kooking im very suprised u didnt get a minor seasure :) .o and not to mension the fact the engine might fall out but hey it aint ure money is it
