Should a 1979 mini with centre clocks have a cover on the hole in behind the centre clocks?
I know minis with the clocks in front of the driver do.
If so where can i get one if not can i fit a later cover?
Firewall Cover
richw911
, Jun 10 2012 08:07 PM
5 replies to this topic
Posted 10 June 2012 - 08:07 PM
Posted 10 June 2012 - 08:24 PM
It is normally wide open, except for a thick piece of sound insulation felt.
Posted 10 June 2012 - 08:26 PM
On cars used in competition that aperture has to be sealed off. I use a flat aluminium plate and use a longer speedo cable which goes in near the wiper motor and runs inside the car with a 90 degree bevel drive into the back of the speedo.
Posted 10 June 2012 - 08:30 PM
Ok many thanks for the help guys great as ever
I want one so think i will make one.
Posted 10 June 2012 - 09:02 PM
The longer speedo cable is an Austin/Morris 1100 one which is about 39" long (from memory). The 90 degree bevel drive to take the cable into the back of the speedo is from a Mk.2 Jaguar.
Posted 10 June 2012 - 09:12 PM
Thank you very much
