Making A Mini Spit/rotator Thing
Posted 12 June 2012 - 10:04 AM
So, what I would like to know is if anybody knows how to make a mini spit? Is there any plans or pictures of ones anywhere?
Thanks!
Posted 12 June 2012 - 10:48 AM
I've spit roasted 2 mini's first we mounted as shown..going through the back window...2nd was a mark 2 and had a hole in the rear seat back, so we went through that hole and through the dash hole...
The 2nd way is better..mini turned a lot easier on the spit. balances better
There's loads of different ways I didn't follow any plans, just measured from the centre dash hole to the furthest outside edge to give me the height I needed.
Used scaffold tubes welded into 2 stands for either end, using scaffold fixings to mount the spit roast main tube on.
heres one made out of wood, with a metal center pole
Edited by lrostoke, 12 June 2012 - 10:56 AM.
Posted 12 June 2012 - 11:02 AM
Posted 12 June 2012 - 11:11 AM
Only disadvantage with those is if you need to replace rear arches ...very rare seat back and bulk head need replacing..
A jigsaw would make a neat hole in the rear seat back, weld the removed section back in when finished..ground back nobody would know :)
Posted 12 June 2012 - 12:02 PM
I've seen them on ebay, but can't find now...
Thats a good point.
Has there been any spit making projects on here?
Posted 12 June 2012 - 04:57 PM
I used the above link for sizes.
I used a hole cutter to cut hole in boot bulkhead, the standard carpenters hole cutter from a cheap set. The circle you cut out can then be rewelded into the same spot when you have finished.
Use a scaffold pole and screw plywood plates onto both bulkheads so the pole goes through the circles you make in the plywood plates (size of whole to suit scaffold tube) and the pole rubs only on the plywood when you spin the mini. I just propped the mini where I needed to work.
The only differnce between the photos above was I used solid ply to stiffen the timbers, not timber diagonal braces. Also the end of the poles sat in super strong plywood braced onto the uprights.
If you get what I mean. Good luck
Posted 12 June 2012 - 05:03 PM
I cut a hole in the back of the seat with a circular hole cutter, you'll never know when I weld it back in!
