Hi there guys,
Just wondering, the later Mini's, the ones with MPi engines specifically, do they have A+ engines?
Thanks!
Ben
Are Mpi Engine's A+?
fattail95
, Jun 12 2012 02:18 PM
6 replies to this topic
Posted 12 June 2012 - 02:18 PM
Posted 12 June 2012 - 02:26 PM
MPI's are all A+, A+ type was fitted from 1982/3 until the end of production
Posted 12 June 2012 - 03:20 PM
Thanks Simon! What are the key differences between the two if any?
Posted 12 June 2012 - 03:24 PM
MPi was the very latest incarnation, and are very different. Alternator mounted to head, Coil pack rather than a distributor, and Oil filter mount directly to the block are a few of the changes just looking at the blocks. All MPI utilised the front mounted Rad, and smaller water pump casting. They are significantly different.
What are you looking at that you need the info?
Posted 12 June 2012 - 03:38 PM
I was just interested!
Posted 12 June 2012 - 03:40 PM
No problem, was just seeing if I could answer a different question.
Posted 12 June 2012 - 05:13 PM
The Mpi is just one version of the A+, the Maestro and Motego also used a 1300 A+ engine but again this was in a different configuration to the 'traditional' one found in the mini.
