Best Flasher Unit / Upgrade?
9 replies to this topic
#1 richw911
richw911
  • 2,084 posts
Posted 12 June 2012 - 06:44 PM
My flasher unit has just died again- thired one on this car in a very short space of time, i know the halfords ones are rubbish but mine have come from mini parts places.
I took the cover off and the cheap metal has snapped inside the same as all the others they are just cheap and nasty. I could solder it bit im sure it will just break somwhere else >_<
My question is where can i get a good one that will last? Is the one you can use off a different car? Modern car?
What do you use? :proud:
#2 charie t
charie t
  • 3,153 posts
Posted 12 June 2012 - 09:39 PM
http://www.ebay.co.u...=item519fb890f9
Something like that, best conversion i've seen on a mini
do the the hazards too. you nned to add an earth to the relay
#3 richw911
richw911
  • 2,084 posts
Posted 13 June 2012 - 08:32 PM
Ok thanks for the help. :proud:
#4 richw911
richw911
  • 2,084 posts
Posted 13 June 2012 - 08:44 PM
Could i use this one?
If so how do you wire it?
#5 matt615
matt615
  • 923 posts
Posted 13 June 2012 - 09:35 PM
Yes that one will work. You wire it the the same way as the old flasher unit, then just need to add an earth to the third terminal. A very quick, easy and worthwhile upgrade.
#6 richw911
richw911
  • 2,084 posts
Posted 13 June 2012 - 10:27 PM
Thank you. I take it you cant use it for both the indicators and hazards? I have two wires on each of my separate flasher units ?
#7 richw911
richw911
  • 2,084 posts
Posted 14 June 2012 - 03:01 PM
Anyone? :proud:
#8 Ethel
  • 26,580 posts
Posted 14 June 2012 - 03:30 PM
Yes it could replace both; it's how it's done on later Minis, with a relay to make the indicators ignition dependent.
#9 richw911
richw911
  • 2,084 posts
Posted 14 June 2012 - 05:39 PM
Many thanks guys :shades:
#10 richw911
richw911
  • 2,084 posts
Posted 21 July 2012 - 06:18 PM
Old Thread revival
Thanks to charlie t i have fitted ford flasher units these are available from 90s fiestas and are cheap.
Thought this wiring pic may help other who upgrade to these :
