I am fitting 4.5*10 minilite wheels with 165*70 tyres to a mk 3 mini 1000 (all drum brakes). I had heard that these would fit without any modifications however it seems that the rear standard shock absorbers are touching the tyre. Has anyone come across this and how did you deal with it?
Minilite Wheels Rubbing Damper.
The Gum
, Jun 12 2012 08:08 PM
2 replies to this topic
Posted 12 June 2012 - 08:08 PM
Posted 12 June 2012 - 08:11 PM
That's why the later cars had spacer drums......so you need to fit either the later drums - or alloy spacers.
Posted 13 June 2012 - 05:37 PM
This would be a good idea however it is only rubbing on one side. The other side if fine. The damper on the side that is rubbing is also correctly positioned, and is in the same position as the other damper!!!
