Have you ever done the tappets/valve gaps? Definitely get a compression test done. If just that cylinder is low, then:
- Piston ring - not heard of many snapping though.
- Tappet/valve gap too tight on that clinders ex/in valve
- Damaged valve/seat
My money's on the latter 2. My mate had a valve burn out on his Triumph (after 7 years and 50,000 miles of running unleaded in a leaded engine, so it did well) - the compressions were ~120psi all across, apart from that one which was 5psi. Took the head off and found a peice of the valve seat had burned/broken away.
Edit: Compression test:
- Take out all 4 plugs (numbering plug leads first)
- Disable coil
- No need to disable fuel
- Put compression tester in plug 1 hole, foot to floor, crank over for 5 seconds, note the reading.
- Do the same for 2,3,4.
I would also possibly do it once when engine is stone cold, and once when fully warm and compare the readings. Mine scared me once giving 0psi on one cylinder when cold. When it was warm it was absolutely fine (~150psi) - think I've got a sticky valve that's not fully closing when cold, but is fine once it warms a little.
Edited by ian2000t, 13 June 2012 - 12:02 PM.
