My 1996 Sprite Auto, Stalls When Put Into Gear ?
8 replies to this topic
#1 minidug
minidug
    Starting My Mini Up
  • 3 posts
Posted 12 June 2012 - 11:17 PM
Hi everyone,
So this is what happened to me today. I was on my way home from a visit to MiniSports and at a set of lights on the dual carriage way i put the car into Drive and try to pull away. It stalled on me. I ended up being helped by the police to push him off to a safer place and have a look.
Im relatively new to the Mini so wasn't really sure what i was looking for to start with. I let it cool down for a while and tried again. This time it went into gear and started to pull forward but as soon as i pressed on the gas it would just conk out !
I managed to get a tow home and start to investigate. What ive found on forums etc is that people with the same problem as mine seem to sort to problem out but replacing the Vacuum Advance Distributor pipe.
Now ive looked and looked and searched my engine and i just cant seem to find one. I mean there must be one somewhere. Or is it possible that i don't have one ?
Well any help would be most appreciated and any other thoughts on what else my have caused the problem let me know.
Cheers,
Neal .
#2 station31
station31
  • 202 posts
  • Local Club: Caledonian Mini Club
Posted 12 June 2012 - 11:49 PM
possible timming issue would be my guess mine used to do that, does it have points or electric ignigtion?
#3 SA MINI
SA MINI
    Previously known as shaunarmes.
  • 1,001 posts
  • Local Club: yet to join HAMOC
Posted 13 June 2012 - 12:08 AM
Yes as above or the idle could be too low & there for cant take it when a gear is selected.
The Vaccume advance pipe should be from the distributor to the front of the carb. Depending on model. The Vaccume advance is in the distributor usually
#4 ShoutforJoy
ShoutforJoy
  • 738 posts
  • Local Club: TMF+, Automatic Mini Register
Posted 13 June 2012 - 06:12 AM
As well as checking the vacuum advance it's worth checking the oil level as this can cause problems like this. I notice that you're new to Minis, so I have copied the instructions for checking the oil level on an automatic - it's not as straightforward as you would imagine.
The correct method to check the oil level in your Classic Mini Automatic is as follows:
1) Park on a flat and level surface.
2) Apply park (hand) brake and park if you have a later 1275 model.
3) Start and warm up the engine.
4) Once warm turn off and wait for 60 seconds, the time is important, i use a stop watch, but the second hand on your watch will do.
5) Now fit the dipstick and retract dipstick to take a reading.
6) Holding the dipstick with the handle slightly higher than the reading area, take a reading.
7) You should aim for it to be at the "Max" point on the dipstick.
8) The difference between the "min" and "max" points is approximately 1 pint (0.6 litre)
9) If you have too much oil you must let some out.
It is important that you follow the above to the letter otherwise you will get incorrect readings from time to time.
There is no transmission fluid in Mini automatics - they share the engine oil and need regular oil and filter changes to keep the transmission in tip top condition and reduce wear. The recommended interval is every 2-3,000 miles or 6 months (whichever comes first). The oil that you use is important too. Most people recommend a mineral oil of 20w50 grade. The auto transmission expert that just rebuilt my transmission recommends 10w40 for newer cars like yours.
If these don't solve the problem come back to us.
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 13 June 2012 - 07:59 AM
Being a 1996, would it not be a single point injection engine rather than carbed ?
IMO, it points firmly at lack of oil or worse torque convertor .
#6 bmcecosse
bmcecosse
  • 9,699 posts
Posted 13 June 2012 - 10:01 AM
Unless the engine is desperately down on power.... is it idling smoothly enough? Does it rev up nicely when not in gear?
#7 minidug
minidug
    Starting My Mini Up
  • 3 posts
Posted 13 June 2012 - 10:06 AM
So ive solved the problem. It was the Vac pipe that was connected from the ECU to the MAP senor. It was sitting on the back of the manifold and burnt through. Just replaced pipe and runs normal whoooooo.
#8 bmcecosse
bmcecosse
  • 9,699 posts
Posted 13 June 2012 - 10:07 AM
Great success!
#9 minidug
minidug
    Starting My Mini Up
  • 3 posts
Posted 13 June 2012 - 11:35 AM
So here is a photo of what happened.
Thanks a lot to everyone for your suggestions.
Neal .
