Electrical Help? Wiring Headlights On A Relay + Replacing Glass For Blade Fuses?
Posted 13 June 2012 - 08:50 AM
thanks in advance
Posted 13 June 2012 - 09:16 AM
Ignore the labels its the terminal numbers that are important.
For main beam it will be
30 connect to battery, solenoid terminal is ideal
85 connect to earth (car body)
86 connect to blue/white wire in your wiring loom... open up the loom on the left inner wing, you can cut the wire there.
87 the other side of the blue/white you cut that runs to the lights
For dipped beam as above on a seperate relay but replace blue/white for blue/red
can't help on the fuse ratings
Posted 13 June 2012 - 10:13 AM
As it happens, I lost both headlights suddenly, in the dark, many years ago, and lived to tell the tale, but it could easily have been fatal. It was not caused by a fuse, but by an incorrectly designed dip switch on a Triumph Herald, which when a bit worn, could stick in an intermediate position with main and dip both off. First drive at night, returning to main beam after a car passed in the opposite direction, the lights suddenly went out, and I was left in utter darkness. The car ended up at right angles in the middle of the road.
There is nothing wrong with fusing left and right seperately, but if you do that you will need more than one relay.
I would advise anyone who is not fully competent in electrical matters to never mess about with their headlight wiring.
Posted 13 June 2012 - 10:22 AM
Appart from the fuse it will work as shown
Although saying that if the relay fails you will lose both lights, I'd guess uber safe would be 2 relays per side,
Then again dodgy mini wiring bundled behind front grill you have a bullet connector with a cruddy fitting you could easily lose both lights.
Edited by lrostoke, 13 June 2012 - 10:25 AM.
Posted 13 June 2012 - 11:50 AM
NO! Do not ever put a fuse or circuit breaker in the headlight circuit. It is illegal and downright dangerous.
Maybe so, but a total headlamp failure is much more likely to occur because of the poor wiring and badly situated connectors installed by BL. Many forum members have being left in the dark by corroded bullet connectors and duff switches (myself included).
Posted 13 June 2012 - 12:13 PM
You will obviously need two separate relays - one each for the dip and main beam. You can use the blue/white and blue/red wires for the headlamps to trigger the relays (86 in the diagrams above). As irostoke suggested you can unwrap a section of the loom on the inner wing to allow you to tap into the headlamp wiring. I did this and at the same time used the opportunity to replace the wiring from this point to the headlamps themselves ad to incorporate wiring for spotlamps. You may find a roll of self amalgumating llom tape useful to rewrap the loom.
The relay holder does look a very neat solution and I cant think of any reason why you could not use it. You would need to think through how you wire it and provide a new power feed and earth fro each of the relays. Maybe the supplier can give you more advice on how the bar is wired.
Incorporating a new fusebox is obviously a complex exercise. I decided to stick with the standard 4 fuse box because most fuse boxes appear to only support a single connection whereas the mini has several connections to each fuse. This is not impossible to work around but adds another level of complexity.
Note that the blade and glass fuses are rated differently so you should not replace one with a blade of the same rating. I think one rating is the maximum continous current and the other is the current which causes the fuse to blow. There are threads elsewhere on the forum diuscussing this.
Posted 13 June 2012 - 12:26 PM
Posted 13 June 2012 - 12:29 PM
When it comes to relays, they are not all that expensive, so if you go that route, you could use 4, one each for main and dip on each side, and fuse the feed to each seperately. That way you get the advantages of being fused plus the safety of having them independent. You might only use 2 fuses, left and right, as modern cars seem to be wired.
Oh, and get rid of the dim dip. It is not required legally, and a well-known cause of headlight failure.
Edited by tiger99, 13 June 2012 - 12:31 PM.
Posted 13 June 2012 - 12:33 PM
Something like 4 or 5 core auto cable to each side
Posted 13 June 2012 - 12:52 PM
Posted 04 July 2013 - 11:34 AM
I can only second that. Am I reading this correctly? You want headlights to come from an ignition dependent supply with no fusing?
I must be reading this wrong - just a quick look at a late mini drawings shows left and right, dipped and main separately fused.
How on earth would wiring the whole kit and caboodle up direct to the battery have help your Herald Mishap? switch was faulty...end of story - no fuse or a thousand fuses, wired direct or ten relays, no difference. Switch didn't provide a signal for the relay/s or direct to the lamp unit makes no difference - no light.
I have to be completely misunderstanding what you say.
Posted 04 July 2013 - 11:42 AM
Missed the fuse on the diagram it was just a generic relay wiring diagram, I did say ignore the labels its the terminal numbers that are important.
You could do, however for every additional unnecessary relay comes yet another 4 connections to fail. Two relays is quite adequate, one main, one dip. You could run full redundant wiring too with all the additional complications.
If you use good quality components and carry out the installation well, then I expect the car will be in the crusher before the relays pack up....all this overkill,but with tungsten filaments
Posted 04 July 2013 - 12:34 PM
Myh example of the Herald is merely to illustrate how downright dangerous a headlight failure can be, and that they do happen. My other remarks are intended to ensure that Mini owners do not fall foul of the law, and add extra failure modes which increase that risk.
Ideally the entire circuit would be independent left and right, with double pole light switch and dip switch, however if changeover relays were used, a single pole dip switch would be ok, as failure would make the lights revert to dip, not go out completely.
Posted 04 July 2013 - 12:47 PM
Captain must be board this topic is 12months old :)
Posted 04 July 2013 - 02:24 PM
Really, it just popped up as a current topic......nonetheless, interesting to read, hopefully people took a great deal of care in picking the best bits of the advice from the thread - Not sure why the thread should pop up as current...SQL can do funny things from time to time...
As for bored - dumbfounded would not adequately describe the happenings of today.
