Valve Stem Oil Seal
4 replies to this topic
#1 H.M.M.
H.M.M.
  • 332 posts
  • Local Club: Witney Invaders
Posted 14 June 2012 - 04:56 PM
I've changed many HG in the past and have always had 8 valve stem oil seals. So no brainer replacing them. My new HG set has only got 4, so do the seals go on the inlet or outlet?
Thanks.
#2 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 14 June 2012 - 04:59 PM
Inlet. It's long been debated about putting seals on the exhaust, even Rover changed their mind.
#3 H.M.M.
H.M.M.
  • 332 posts
Posted 14 June 2012 - 05:06 PM
Cool, thanks for that, (grabs his brolly and goes to the shed to finish the re build)
#4 mini mayhem
mini mayhem
  • 307 posts
  • Local Club: Mini Club Of Ireland
Posted 18 July 2012 - 06:33 PM
Why is this, it is baffling.
#5 MiniElliott
MiniElliott
  • 378 posts
Posted 19 July 2012 - 08:55 AM
Because oil will be sucked into the inlet along with fuel to be ignited. If oil is sucked in throug the exhaust it will be pushed out through the exhaust system. However it could still burn in the exhaust so I cover all the valve stems with seals.
