Rolling Road For Bike Carbs. Midlands
Posted 15 June 2012 - 02:22 PM
Posted 15 June 2012 - 02:50 PM
Steve
Posted 15 June 2012 - 03:42 PM
Posted 15 June 2012 - 11:49 PM
Posted 15 June 2012 - 11:52 PM
Sorry i cant help with your question but do you have any pics of your carb set up and also a quick how to guide on the conversion, also what did you use for the inlet manifold? I made a tam plate of a stage 1 manifold then cut it on a 8mm ally plate I made two of them then I welded two 32mm diameter tubes to the plates and then used dremele to port the joins in side then two samco hoses holding the carbs to manifold and u have to Wales the tubes at an angle for the bike can't float a
Steve
