Rod Type Gear Change To Solid Remote Type Conversion
Posted 15 June 2012 - 05:05 PM
If this is possible is there going to be any major fettling required? or any problems with doing this?
Sorry for the daft question but its something i would like to know.
Steve
Posted 15 June 2012 - 05:25 PM
Posted 15 June 2012 - 05:57 PM
Steve
Posted 15 June 2012 - 06:12 PM
Also, if you're finding the rod change 'sloppy', then it may be worth popping the gearstick out and having a look at the condition of the nylon ball on the end, these do wear and can give a terrible feel to the gear change. Problem is I've never found a way to change one other than changing the gear stick.
Posted 15 June 2012 - 06:30 PM
Posted 15 June 2012 - 07:00 PM
I've done this on a Clubman GT with an 'S' engine & box, but it was a while ago.
Quite a big job if it's just because the rod linkage may be worn and need replacing.
Posted 15 June 2012 - 07:16 PM
Posted 15 June 2012 - 07:18 PM
Posted 15 June 2012 - 07:41 PM
And errr - if your original idea was to simply put a remote on your existing gearbox - fraid not - can't be done......
Edited by bmcecosse, 15 June 2012 - 07:42 PM.
Posted 15 June 2012 - 08:00 PM
The switch components come from the MG-1100 and Austin America remote gearboxes. The last time I checked, Holden.co.uk had the switches. You may have to make the plunger and improvise the spring but it would not be a hard thing to do.
Adjusting the switch's trip point is handled by the number of gaskets fitted between the switch and the gearbox.
http://home.mindspri...verseswitch.jpg
Posted 15 June 2012 - 09:25 PM
with this rebuild i have planned it to take me at least 2 years due to finances, and myself doing 90% of the work, it seems a long time but i need to make sure its as I want it without compromise. plus its going to be a steep learning curve, and i am sure will make mistakes along the way.
once again thanks for the help I wasn't sure it was do-able but I am glad it is.
Thanks all
Steve
Posted 16 June 2012 - 12:15 AM
The switches from the ag-supply store may be the correct one. You can reference the dimensions in the link I posted above. If the plunger is any larger than shown in the sketch it will not work in the Mini.
Posted 16 June 2012 - 06:12 AM
these switches are available at most agricultural/tractor supply type places......
....or a gearbox specialist ;)
Posted 16 June 2012 - 10:37 AM
