Fag Lighter For Sat Nav
14 replies to this topic
#1 matthewrussell
matthewrussell
  • 378 posts
Posted 16 June 2012 - 06:55 AM
Are the fag lighters a good idea to install in a mini ???
#2 rob963
rob963
  • Just Joined
  • 350 posts
Posted 16 June 2012 - 06:58 AM
I would definitely say so,
I installed on in my mini last month and have used it for all sorts of things :)
And they are easy enough to wire in :thumbsup:
#3 matthewrussell
matthewrussell
  • 378 posts
Posted 16 June 2012 - 07:01 AM
Right kk thank you :) will buy one off eBay now
#4 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 16 June 2012 - 07:22 AM
http://www.ebay.co.u...984.m1555.l2649 :-)
Drop me a PM if interested
Steve
#5 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 16 June 2012 - 07:50 AM
No.... because smoking is bad for you and your mini may get lung cancer, but the socket does come in handy for things like Sat Nav & mobile phone chargers I suppose!! :P
#6 dennismini93
dennismini93
  • 1,093 posts
  • Local Club: nsmoc
Posted 16 June 2012 - 08:29 AM
my car came with one and its very useful, until i found it that it was poorly wired into my radio and the loose connection was why it kept turning off
#7 Wakey-Dan
Wakey-Dan
  • 256 posts
Posted 16 June 2012 - 08:34 AM
I've always fancied one but never got round to it. what do you wire it to?
#8 grumpy2
grumpy2
  • 613 posts
  • Local Club: Wirral Minis
Posted 16 June 2012 - 08:38 AM
I have one descretely mounted wired from the fuse box with a 15 amp inline fuse. Use it for all sorts, satnav, phone charging, running inverter
Very useful, just wire it correctly
#9 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 16 June 2012 - 09:03 AM
Taking a live feed from a spare terminal on the fuse box, or directly from the starter motor tend to be the popular choices. It also seems a common practice to take a feed from the stereo too, but this really should be avoided so as not to overload the circuit.
#10 rickthirteen
rickthirteen
    Starting My Mini Up
  • 3 posts
Posted 23 June 2012 - 10:36 PM
sounds good - any tips/pics for mounting it in the car
#11 GTIAlex06
GTIAlex06
  • 1,562 posts
Posted 23 June 2012 - 10:53 PM
Keep meaning to do this but i have no idea/car electrics scare me slightly to be honest.
Maybe il give it a go.
A guide which pictures would be nice even thou it sounds easy enough
#12 Alex_B
Alex_B
  • 4,573 posts
Posted 23 June 2012 - 11:19 PM
There wouldn't be much in a picture, all you need is to take a fused live from either a switched location ( somewhere on the fusebox that gives 12v when ign is on) or a permanent location (always gives 12v ) to the positive feed on the socket, and then connect a earth to a location on the shell.
You will have some math to do with regard to wire rating and fuse rating, need to make sure the wire can handle the amount of power being used for in the socket, and that if that power is exceeded then the fuse needs to blow before the wire gets close to melting / catching alight.
#13 rob963
rob963
  • Just Joined
  • 350 posts
Posted 23 June 2012 - 11:21 PM
well, I can take some pictures tomorrow if you like?
an in-line fuse is always a good addition to keep it safe :proud:
But it is very easy to install :thumbsup:
#14 Rabtmac
Rabtmac
  • 195 posts
  • Local Club: Looking for one close to me
Posted 23 June 2012 - 11:49 PM
Going to install one myself as soon as it stops raining >:( just bought one off Ebay (thanks Stevede)
My wireing has been needing sorting out for a while now so steadily working through all the old bodge ups the previous owners have done,
thought id have a look at a button start lol took about 5 minutes just need to work out how to isolate the the feed wire through a switch to make it a little safer. ^_^
#15 leroy26
leroy26
  • 2,239 posts
  • Local Club: minisunleashed.com
Posted 24 June 2012 - 06:12 AM
took my wiring from the radio live ( as i dont have a radio!! :D)
then earthed it to the holes under the dash where the rsdio mounts also mounted it there in the passenged side, also put an inline fuse in it
