Spray Gun Nozzle
9 replies to this topic
#1 bluemini1979
bluemini1979
  • 619 posts
  • Local Club: Colchester Mini Club
Posted 16 June 2012 - 07:19 PM
Hi
im going to be repraying some parts for the mini. what is the best size gun nozzle to use. also is a gravity feed or suction type best?
thanks
david
#2 jpw1275
jpw1275
  • 2,803 posts
Posted 16 June 2012 - 07:21 PM
Hi, I normally use a 1.4 nozzle and a gravity gun
Cheers james
#3 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 16 June 2012 - 07:31 PM
I use 1.4 suction for cellulose.
#4 bluemini1979
bluemini1979
  • 619 posts
Posted 16 June 2012 - 07:42 PM
i will be using 2 pac. and using safety gear lol
#5 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 16 June 2012 - 07:43 PM
Gravity fed may be better in that case then :)
#6 bluemini1979
bluemini1979
  • 619 posts
Posted 16 June 2012 - 08:03 PM
with the same size nozzle? :)
#7 corrado vr6
corrado vr6
  • 678 posts
Posted 16 June 2012 - 09:16 PM
for filler primer 2k i use 1.4mm
and for basecoat and clear coat i use 1.3mm
so you could probably be ok with 1.4mm as an all rounder
edit to say thats a gravity fed gun and DeVilbiss is one id recomend
Edited by corrado vr6, 16 June 2012 - 09:18 PM.
#8 jpw1275
jpw1275
  • 2,803 posts
Posted 17 June 2012 - 05:36 PM
Yea I use 1.4 and gravity gun for 2 pack
Cheers james
#9 Tomm
Tomm
  • 2,462 posts
Posted 18 June 2012 - 11:40 AM
I am using a 1.4mm suction feed with 2K at the moment and I can not get on with it at all. I am trying to get hold of a new gravity feed to give that a go.
I also find it annoying having to paint the flat surfaces first with a suction feed gun, bonnet, roof, tops of wings etc as when you get to the bottom of the can it has to be held upright so that the last 1/4 of the can can be used.
If that makes sense?
#10 JonnyBMX
JonnyBMX
  • 865 posts
  • Local Club: Rebels
Posted 18 June 2012 - 12:20 PM
for 2k high build i use a 1.8mm gun £25 fastmover one does the job
then for basecoat and laquers a 1.4mm devillbliss
both gravity fed
