Thermostat Housing Bolts
5 replies to this topic
#1 zeroasylum
zeroasylum
  • 378 posts
Posted 19 June 2012 - 10:11 AM
I have a quick question I need to change my thermostat. Now the car is a 1990 998 so I ordered a new stat and just encase a fitting kit but when I just had a look at my housing it is held on with bolts not studs but does not have a sandwich plate. Anyone know what type length bolts these are so i can order some from Minispares.
Zeroasylum
#2 cal844
cal844
  • 9,646 posts
  • Local Club: TFMOC
Posted 19 June 2012 - 10:33 AM
pm [email protected] he will tell you mate
Edited by cal844, 19 June 2012 - 10:34 AM.
#3 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 19 June 2012 - 11:09 AM
You can just fit studs if you want, mind you there's nothing that wrong with having bolts, the Metro A-Series used them I believe.
D
#4 zeroasylum
zeroasylum
  • 378 posts
Posted 19 June 2012 - 11:48 AM
D
I would like to fit the bolts hopefully can reuse the ones in there but just encase I wanted to pick some up. I know the studs were 5/16" unc so assume the bolts are the same but not sure of the length.
Zeroasylum
Edited by zeroasylum, 19 June 2012 - 11:49 AM.
#5 Ethel
  • 26,078 posts
Posted 19 June 2012 - 12:20 PM
DAM7760 - Bolt 5/16unc x 2 1/2" for all stats with sandwich plates.
CHS2515 - Stud 5/16 unc/unf x 1 7/8" no sarnie plate.
I'd say a 1.5" to 1.75" would do http://www.a2stainle...ter_B22SKY.aspx
or DAM7759
#6 tom1234177
tom1234177
  • 369 posts
  • Local Club: TMF & BMC
Posted 19 June 2012 - 02:24 PM
If it's studs you want - Look here!
