Earth Strap
Posted 21 June 2012 - 02:28 PM
I ask because mine disappeared a couple weeks ago but everything is still functioning normally ?
Posted 21 June 2012 - 02:35 PM
Posted 21 June 2012 - 02:43 PM
Does what it says on the tin, and completes the power circuit. Get it replaced ASAP, as it will currently be earthing through accelerator cable, choke cable etc. Sooner or later your battery won't be at its full charge, and you'll be unable to start the car.
Gotcha, thanks man, I'll get it replaced.
Explains why my last battery went duff.
Edited by Lewis998, 21 June 2012 - 02:43 PM.
Posted 21 June 2012 - 02:48 PM
Posted 21 June 2012 - 02:50 PM
Thanks Simon.
Posted 21 June 2012 - 05:45 PM
Posted 21 June 2012 - 05:49 PM
This is strange, mine was worse when it was hot when the earth strap was broken. I put it down to the fact that the pistons were tighter in the bore, meaning more amps were needed to turn the engine over. It would have the symptons of a flat battery. As soon as renewed the earth strap, it cured it.That would do it..... symptoms generally are more pronounced in the cold. Check the state of your choke, heater and throttle cables as well now, they can melt when acting as an earth for any lenght of time
Edited by Spud_133, 21 June 2012 - 05:50 PM.
Posted 21 June 2012 - 05:50 PM
The straps are quite cheap so may be an idea to fit two at different places wont be a problem again :)
Good idea this, anywhere from the engine to the body with clean, fairly thick metal at each end is ideal. I had problems with a dodgy earth and added another for insurance.
Posted 22 June 2012 - 09:02 AM
Posted 22 June 2012 - 09:32 AM
I wouldn't think the pistons would be tighter seen as all the engine parts expand when hot, not juts the pistons.
Posted 22 June 2012 - 10:41 AM
Clearances are looser when cold to allow for alu expanding more than cast iron.
Posted 22 June 2012 - 11:45 AM
Posted 22 June 2012 - 02:15 PM
The earth strap connection between battery and body can also be dodgy.
Very true, especially as it bolts to the boot floor..... and we all know what boot floors are notorious for!!
