Enamel Paint Query
7 replies to this topic
#1 leepol83
leepol83
  • 1,744 posts
Posted 21 June 2012 - 09:47 PM
Hi chaps you will be hearing from me quiet abit over the nxt 3 years :)I've just bought a mini that has been painted with enamel paint my question is can I just sand and etch prime over this or will I have reaction problems further down the line when normal paint is used.
Thanks guys any advice more than appreciated.
#2 jpw1275
jpw1275
  • 2,803 posts
Posted 22 June 2012 - 05:55 AM
Im no expert but at a guess id say it would react as im sure enamel paint is oil based but im sure someone will clarify
Cheers james
#3 leepol83
leepol83
  • 1,744 posts
Posted 22 June 2012 - 09:21 PM
Thanks James I will see what people say cheers again mate.
#4 fikasteve
fikasteve
  • 124 posts
Posted 22 June 2012 - 09:29 PM
I'm currently painting my mini with a roller and enamel type paint and ive been told that i cannot spray over this in the future. Rustoleum is the paint ive used if that helps.
#5 03jkirk
03jkirk
  • 465 posts
Posted 23 June 2012 - 06:36 PM
etch primer would not be a good idea as it is acidic and is used for bear metal to etch in as the name implys so ontop of other paint it will most likely react and lift the underlying paint off the body
#6 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 23 June 2012 - 06:48 PM
I've regularly sprayed etch primer onto exposed bare metal that's surrounded by existing paintwork, and I've never had any reaction problems where the etch has come into contact with/covered over the surrounding paint. That's always been with celly based paints though, it might be a different story with enamel based paint I suppose. :unsure:
Edited by AVV IT, 23 June 2012 - 06:48 PM.
#7 03jkirk
03jkirk
  • 465 posts
Posted 23 June 2012 - 06:55 PM
ye with the reaction i m only assuming from my knowledge of chemisty but as i sed be4 etch primer is designed for bare metal anyway so is the incorrect paint to use in this situation
#8 leepol83
leepol83
  • 1,744 posts
Posted 23 June 2012 - 09:16 PM
Sweet thanks chaps i will just get it stripped to bare metal looks like there won't be much original paint left by the time I've replaced pretty much every panel anyway ha ha!!!!
