hi guy's somone used the turm pinking but i have no idea what it is could someone explain cheers.
Whats Pinking ?
jaysmini30
, Jun 24 2012 02:20 PM
6 replies to this topic
Posted 24 June 2012 - 02:20 PM
Posted 24 June 2012 - 02:21 PM
In what context mate lol
Posted 24 June 2012 - 02:28 PM
The fuel-air charge is meant to be ignited by the spark plug only, and at a precise time in the piston's stroke cycle. Knock occurs when the peak of the combustion process no longer occurs at the optimum moment for the four-stroke cycle. The shock wave creates the characteristic metallic "pinging" sound, and cylinder pressure increases dramatically. Effects of engine knocking range from inconsequential to completely destructive.
Posted 24 June 2012 - 02:30 PM
as above really... it's when the engine 'knocks' because the ignition/mixture's not right. It can (will) damage your engine
Posted 24 June 2012 - 02:31 PM
It's also called pre ignition, dieseling , or pinging. It's when the fuel ignites before the spark plug fires because of heat & pressure (like a diesel), it sounds like a ping, or "pink", hence those names. The danger is that it develops into detonation, that's when all the fuel explodes before the piston gets to top dead centre and the combustion temperature soars to the point where it's hot enough to melt things.
Posted 24 June 2012 - 03:39 PM
Pinking can be bad -
Never did find that chunk of piston that broke off!
Posted 24 June 2012 - 04:45 PM
wow ok then thank you guy's it's my mates riley it suffer's from it.
him and his friend were talking and he said it had pinking i didnt have a clue so i didnt look an idiot i just went along with it lmao
surely you would loose power from this and would be able to tell ?
