I first noticed the problem when I saw a oil leak under the car, not huge just a few drops. So I jacked the car up for a look and found it coming from where the pot joints go into the diff, with the pot joints themselves far enough away from the gearbox to be able to get my finger in the gap! (Both sides are the same)
Right, I thought, it must be the circlips holding them on the splines. So yesterday I changed the circlip on either side, put it all back together and jobs a good 'un. The pot joints went all the way on the splines and were right up against the diff casing like they should be. I went for a drive and everything seemed fine. I've been driving round today and thought I'd have a little look to make sure everything is still good and I noticed that there is a gap between the pot joint and diff casing again, grrrrr.
So my question is why aren't the pot joints staying put?? They were new when I restored the car but I can't get my head around this problem, are there different types of pot joint and I've got the wrong one or something?
Any help would be great.
Edited by minichick, 25 June 2012 - 05:58 PM.
