Hi,
just wondering what pressure I spray stonechip at using the shultz gun ??
Graham
Stone Chip Pressure
grahama
, Jun 25 2012 06:44 PM
7 replies to this topic
Posted 25 June 2012 - 06:44 PM
Posted 25 June 2012 - 06:59 PM
It's not so much the pressure, but the volume of air...
Adjust your pressure to give you the rate of deposit you're comfortable with, but what I do recommend is putting the tin in hot water beforehand to loosen it up, flows a lot better then.
Posted 26 June 2012 - 04:24 PM
I spray gravitex at about 80
Posted 26 June 2012 - 05:54 PM
ok ta fellas, i have a variable pressure regulator to attach to the gun so will play about in the boot first before atacking the underside.
Posted 27 June 2012 - 06:38 PM
Well, set the pressure to 50 bar and held about 12" away and this is what I got
It still seemed a little thin inplaces next to thick sections, but I am sure I went over as many times !!
All in all quite pleased for a first go, thanks for the help,
Graham
Graham
Posted 27 June 2012 - 06:41 PM
50 bar Graham???? you mean 50psi.
Anyway give it at least 2 decent coats maybe three underneath. Pay plenty of attention to all of the nooks and crannies
Posted 27 June 2012 - 06:51 PM
50bar is about 425 PSI graham
. Looking good though
Posted 27 June 2012 - 07:04 PM
lol, psi !! will get another few cans then and I can also get the parts I missed
