Breather Pipe ?
#16
Posted 25 June 2012 - 08:45 PM
#17
Posted 25 June 2012 - 08:49 PM
#18
Posted 25 June 2012 - 09:54 PM
Posted 26 June 2012 - 06:50 AM
#20
Posted 26 June 2012 - 09:29 AM
It seemed like you didn't in your above posts, trace it you'll see where it goes. The mini is a small engine, not difficult to see where it all goes.
#21
Posted 26 June 2012 - 11:43 AM
Did you try and trace the broken pipe to see where it went?
No pipe ...
#22
Posted 26 June 2012 - 12:00 PM
It usually connect to to the carb via "y" piece in-between the tube that comes from the clutch end to the carb, which I believe you already have plumbed in?
should look like that, its not the same carb (HIF) but same principal: (ignore the drawing on it. its the tube that has the joint in it)
Edited by freshairmini, 26 June 2012 - 12:00 PM.
#23
Posted 15 July 2012 - 07:35 AM
