Megajolt Backfiring Through Carb
Posted 26 June 2012 - 08:46 AM
Got my Megajolt wired up to my 1275 MG Metro engine yesterday. From what ive read it is advisable to get the engine running in 'limp' mode before connecting the MJ unit to the wiring. However Im suffering backfire through the carb. Spark is strong but the carb is running at a base setting at the moment as I stripped it and rebuilt it just before fitting the MJ.
Am I right to think there is too much advance?
Any advice on how to go about rectifying this or is it worth trying to get it running with the MJ unit plugged in and adjust the timing?
The trigger wheel is a machined and welded part I bought off Wilson1330 so it cant be adjusted.
Thanks in advance.
Posted 26 June 2012 - 09:34 AM
when i started my car sunday it was firing through the carb because the dizzy is 180 degrees out, swaped the leads around and now its fine :)
try that?
Posted 26 June 2012 - 11:23 AM
Posted 26 June 2012 - 11:35 AM
Posted 26 June 2012 - 02:54 PM
Posted 26 June 2012 - 08:59 PM
Posted 29 June 2012 - 04:24 PM
Posted 29 June 2012 - 05:26 PM
Posted 29 June 2012 - 06:19 PM
Posted 05 July 2012 - 01:40 PM
I suppose I should add:
Plugs are connected in number order as follows: (flywheel) 4-3-2-1 (rad)
There is a permanent live and a good earth.
Fuel is brand new Shell super unleaded (tank was drained and carb emptied).
Car wont run in limp mode or plugged into the MJ.
MJ will speak to the computer fine and I get load readings, however there is no change in RPM gauge while its turning over?
Edited by Tommyboy12, 05 July 2012 - 01:47 PM.
Posted 05 July 2012 - 01:50 PM
Posted 05 July 2012 - 06:14 PM
Posted 05 July 2012 - 08:22 PM
So coil 1 to cyl1, coil 2 to cly2 you get the picture
Im still trying to get this started. I dont suppose anyone has a map for an MG Metro cam. Its just coughing and spluttering while cranking and not starting.
Posted 05 July 2012 - 09:11 PM
I hope what you mean is that the missing tooth passes the sensor 90 deg before tdc when the engine is turning in the normally rotating direction.Checked it today. The leads are firing in the right order and the sensor is 90 degrees before tdc. I played some more but it was still only coughing and backfiring...
It sounds like (in old standard distributor engines) 180deg out of sync.
Just for kicks, try interchanging leads 1 with 2 and 3 with 4.
Posted 06 July 2012 - 08:22 AM
That is how they are wired up. As I said. Plugs are connected in number order from rad to flywheel.You need to connect them 1 2 3 4 as its wasted spark. Not in he mini firing order!
I tried interchanging the leads and the engine locked while turning it over. I will double check the missing tooth. That would be the only thing I havent checked more than once...
