The missing tooth is nine teeth down from the TDC timing notch at around 92-93 degrees. As you can see from the second picture the sensor sits at around 100 degrees when the engine is at TDC. Does this mean the sensor needs moving forward 10 degrees?
Edited by Tommyboy12, 14 July 2012 - 02:37 PM.
