Bullet Shaped Doors Mirrors To A Mini Mayfair 1993
4 replies to this topic
#1 lapsang1979
lapsang1979
  • 12 posts
Posted 28 June 2012 - 09:28 AM
Hello
I'm making a few cosmetic changes to my Mini Mayfair from 1993 including putting bullet shaped door mirrors on instead of the standard. Has anyone had any experience of this? Is it an easy job?
Lapsang1979
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 28 June 2012 - 10:52 AM
make sure you buy door mirrors not wing mirrors
stick a wing mirror on a door and they are useless
#3 surfblue63
surfblue63
    TMF fantasy F1 winner 2012
  • 2,539 posts
Posted 28 June 2012 - 10:58 AM
I have these on mine, sadly no longer available.
There is a new version with a more rounded mounting plinth, which Huddersfield Mini Spares sell.
http://www.minispare...38&prod_id=2161
The bullets don't give as good a view as the standard ones, due to the glass size, but if you are in the habit of glancing over your shoulder to look at the blind spot then it isn't a problem.
Edited by surfblue63, 28 June 2012 - 11:04 AM.
#4 minitman
minitman
  • 74 posts
Posted 28 June 2012 - 11:08 AM
I fitted mine, and they were just a bit of a tight squeeze. Be careful how the mirors attach to the body. the ones I bought are held on from the inside by bolts (probably wing mirrors? Thanks Bungle) and I had to remove the door cards and the outside window rubber seal. Wind the window down, drill the holes whilst holding something down inside the door to protect the window. Then fiddle with a magnet on a spanner to position the bolts. Quite a mess around really. My originals just self tapped on with covers over them but make sure you check when you buy them. the only other thing is the nearside mirror can be difficult to position due to the low height of the door top. Good luck.
Minitman
#5 dave-88_123
dave-88_123
  • 302 posts
  • Local Club: jurrasic coast minis
Posted 02 July 2012 - 06:49 PM
as said dont buy the really cheap ones that have no movment on the mounting as there ment for wings not doors and are usless
