I have a 998cc A+ engine 1989 with electronic ignition and i can't get it to start. It turns over but that's it
Before this problem with it not starting i was getting sooty plugs,rough idling and sounding like the leads were on wrong way round. So to help the problem i fitted new spark plugs NGK BP6ES gapped at 32thou and reset the valve clearances but wonder if i did it right? seems worse since and lead to it not even starting.
Here's a piccy is this the right way to gap them? I have been turning the fan blade till a valve gets fully compressed/squashed then using the power of nine and checking the other valve gap.
:Example valve 3 fully compressed check clearance on valve 6
Hope someone can help
Edited by longbridge4life, 28 June 2012 - 01:22 PM.
