Is This The Clutch Slave Cylinder?
9 replies to this topic
#1 Wilhelm
Wilhelm
  • 103 posts
  • Local Club: Bomber County Mini's
Posted 29 June 2012 - 12:11 AM
My clutch has no 'feel to it' and won't engage. Had to have the brakedown man come pick me and the car up to get me home :(
When I push the clutch pedal down, it leaks clutch fluid onto the floor under the car, what are the chances this is coming from the Clutch Slave Cylinder?
Got to drive the Mini to the airport on Monday so hoping to have her fixed by then! :)
#2 Ethel
  • 26,104 posts
Posted 29 June 2012 - 01:20 AM
Pretty high. As the clutch wears the piston moves further & further down the cylinder, quite often the cylinder is corroded at the open end 'n the seal leaks when it encounters the rust. A good botch is to add some packing to the end of the push rod to move the piston back down the cylinder bore.
#3 jamesy
jamesy
  • 210 posts
Posted 29 June 2012 - 06:46 AM
minispares do a repair kit, and if you follow the haynes manual its a nice easy job to do. :)
#4 Doz1971
Doz1971
  • 209 posts
Posted 29 June 2012 - 07:39 AM
New cylinders aren't that expensive, and if you have a rusty bore, maybe a far better option.
If you do have a risty bore, and don't want to go to the expense of a new cylinder, when you change the kit, clean the rust off with some fine emery paper and some wd40. Clean it all up before fitting the seal kit.
#5 Wilhelm
Wilhelm
  • 103 posts
Posted 29 June 2012 - 08:57 AM
Thanks for all your replies, I don't really have time to order anything in, so I'll have to try and source the parts locally (as I need the car for Monday :) )
Will either of these fit? my car is a 1981 1000 and these kits are under 'rover mini's' at rimmer brothers, worth a shot? :)
http://www.rimmerbro...m--i-BHM7127EVA
http://www.rimmerbro...Item--i-GRK3007
#6 Doz1971
Doz1971
  • 209 posts
Posted 29 June 2012 - 11:11 AM
Those are for the master cylinder. You'll need to look for slave cylinder.
#7 Ethel
  • 26,104 posts
Posted 29 June 2012 - 11:14 AM
They are both master cylinder kits, try your local motor factors. Peel back the rubber dust cover on the slave, it'll be wet with fluid on the inside if it's leaking that badly.
http://www.rimmerbro...m--i-BAU1791EVA - assuming it's a Verto clutch
#8 Wilhelm
Wilhelm
  • 103 posts
Posted 29 June 2012 - 12:58 PM
It's pre-verto I think as it's an '81 :(
I gave them a call and they recon that have a pre-verto one in so i'll pop down later and check :)
#9 Ethel
  • 26,104 posts
Posted 29 June 2012 - 01:13 PM
Pre Verto has a fluid seal that's a disc, no hole in the middle like the Verto's
Posted ImageVerto
Posted ImagePre Verto
#10 Wilhelm
Wilhelm
  • 103 posts
Posted 01 July 2012 - 10:39 AM
Went to rimmer brothers yesterday and got meself a pre-verto kit, took the old seal out and it's split right down the middle :ohno:
replaced it with a new seal, put it back together, put new fluid in, bled the clutch and it's good as new :D
Thanks guys :D
