Signs Of Radiator Coolant On Spark Plug
Posted 30 June 2012 - 12:40 PM
I thought I would keep my previous post about timing methodologies and mixture adjustments separate to this, although the two issues may very well be related.
Taking the spark plug out of #2 cylinder, I can see signs of my green coolant. is my engine screwed, or is my engine irreparable ?
Can cracks in cylinder walls / my head, wherever it may be, be fixed ?
I have a vacuum gauge on my inlet manifold which is fairly steady at idle.
Apart from the timing and mixture, the engine is behaving fine.
if anybody can reassure me as to there not being a bad crack somewhere, I might sleep this week.
B
Posted 30 June 2012 - 02:02 PM
re torque head
is nos 2 dead -- if coolant was leaking in , it should be missing on that cyl
If it was me I would check comp , then whip the head off - & new head gskt
hopefully something simple
a steady vac needle , usually indicates a balenced engine
Edited by sledgehammer, 30 June 2012 - 02:04 PM.
Posted 30 June 2012 - 02:11 PM
Posted 30 June 2012 - 02:20 PM
i dont have a compression tester.
why would it be missing altogether though - I would have thought it would fire, just not as efficiently.
ok, the vac needle is steady, most of the time, there was a point it was jumping around 4 (mmHg - not sure what psi that equates to) at idle.
yeh I agree, hopefully something simple. at least i'll get some sleep tonight.
Posted 30 June 2012 - 02:22 PM
what is the heaterpipe gasket though ? where is it located ? is it on the head ?
Posted 30 June 2012 - 02:25 PM
I wonder if as callum suggests , it could be antifreeze on the outside of the plug running down the plug as you undo it
onto the electrode - you may not immediatly notice it
think cheap & keep fingers crossed
Edited by sledgehammer, 30 June 2012 - 02:28 PM.
Posted 30 June 2012 - 02:39 PM
http://www.minispare...36&prod_id=1457
the gasket for that i may be wrong but if its cylinder 2 then its on the same side and it may be running down onto the sparkplug that was what was wrong with mine
Posted 30 June 2012 - 02:51 PM
My best guess is the head gasket is blown. Especially considering it was running a little warm a couple of times...
SLedge, no, there wouldn't have been coolant outside the plug, definitely came from inside the cylinder. It was on the electrodes..
Posted 11 July 2012 - 06:39 AM
IMG_2049.JPG 86.8K
36 downloads
Edited by b80ven, 11 July 2012 - 06:59 AM.
Posted 11 July 2012 - 08:07 AM
Posted 27 July 2012 - 04:53 AM
yes I did drain the coolant before removing the head to avoid making a mess.
If you look closely, yOu can see a bit of oil in cylinder #3. The engineer I took it to was saying oil was leaking via the valve guides, or, i have a blown compression ring. I really hope I don't have a blown ring, which would mean the engine will need to come out. Something I'm hoping to get away with for the time being, until I'm ready to rebuild it.
