Fuel Pump Failure
Posted 01 July 2012 - 02:35 PM
My Austin mini 25 started this morning with some choke, as i kept her running, she died then wouldn't start anymore, only turning over. A chap looked at it with me and said its most likely the fuel pump because as I was turning over the engine, nothing was entering the filter.
Now bare with me as I'm not the most mechanically minded person but how easy is it to change the pump? I assume its at the back of the engine under the air filter? I have bought a mechanical pump to fit but just want to know what I'm getting myself in for!
Thanks in advance
Posted 01 July 2012 - 02:41 PM
Hope this helps
Posted 01 July 2012 - 02:51 PM
Posted 01 July 2012 - 03:12 PM
Edited by MiniFTW, 01 July 2012 - 03:14 PM.
Posted 01 July 2012 - 03:15 PM
Posted 01 July 2012 - 03:39 PM
but getting back on was a nightmare
i have a LCB on, its getting the bolt back in nearest the clutch side
with keeping the gasket in tact, it was an awful job
took me 3 hrs. never been so frustrated
you may be able to get off from underneath if have access to a car ramp ??
Posted 01 July 2012 - 03:57 PM
Posted 01 July 2012 - 04:03 PM
Start simple
Posted 01 July 2012 - 04:08 PM
Posted 01 July 2012 - 04:10 PM
Posted 01 July 2012 - 05:27 PM
Posted 01 July 2012 - 06:56 PM
As Roy suggested above, disconnect the fuel line at the carb, put the disconnected hose in a catch can and have an assistant crank the engine on the starter to see if fuel is flowing. If it is, the problem is likely to be a stuck float valve in the carb not the fuel pump.
There are complicated fixes to stuck float valves but the simple fix is... rap on the side of the float bowl with the plastic handle of a big screwdriver. The shock typically knocks the valve loose so the fuel can enter again.
Posted 01 July 2012 - 10:08 PM
Posted 01 July 2012 - 11:49 PM
