1966 mini with hydrolastic. full renovation in progress(slowly)- have bought some plastic hydro pipes on ebay. The front subframe is out- then i checked the pipe for length. The pipes are too long by approx 18inches (0.5m.).
The pipe seems to be a thermo setting plastic, with a single flare at the union ends. is it possible to cut and reform the flares of ther pipe? Other possibilities is to have a loop in the system(not my fav soloution), or to have the steel pipes replaced with new ones.
Comments are welcomed.
Hydrolastic (Plastic) Pipes
Miss Piggy
, Jul 02 2012 11:30 AM
2 replies to this topic
Posted 02 July 2012 - 11:30 AM
Posted 02 July 2012 - 07:26 PM
If you are doing a full restoration then would strongly recommend fitting the replacement copper/kunifer hydrolastic pipes that you can get from Minispares or similar.
Plastic pipes were used as a quick fix when the original steel pipes rusted through, as they could be fitted without needing to drop the subframes.
Posted 02 July 2012 - 08:18 PM
Thanks for the reply- I will go for the cupper piping
