Here i have a perfect vauxhall c20xe engine package. this is perfect for any vauxhall build and at extremely good bargain. below is the list of what will be included in the package.
. complete running head and block
. f20 gearbox no crunches plus nearly new clutch
. complete inlet manifold
. powercap
. gas flowed throttle body
. radiator and all coolent hoses
. full wiring loom
. unlocked ecu
. fuel pump
. 4.2.1 manifold with new lambda sensor
. complete airbox and afm sensor
. sump with new baffle plate fitted
. gear linkage and shifter
. altenator
. starter motor and all sensors
. both driveshafts
. recently had a new cambelt
this is perfect for an xe project on any mini and its going for a bargain. i am doing xe build myself but this is out of my daily runner. i am looking for £650.
if anyone is interested pm or contact me anytime on 07984600536
Mini Vauxhall C20Xe Engine Conversion Package
mickyh
, Jul 02 2012 11:02 PM
1 reply to this topic
Posted 02 July 2012 - 11:02 PM
Posted 03 July 2012 - 03:17 PM
I wouldn't call that an "extremely good bargain", more like horrendously expensive. It sounds like a pretty bog standard XE, so I'd value that at around £350 absolute tops, if the top end doesn't rattle and the rings are good. If the 4-2-1 is an aftermarket item, maybe a bit more.
You could buy a whole car with that engine for £650.
Edited by HARBER07, 03 July 2012 - 03:18 PM.
