Water Loss
11 replies to this topic
#1 Jaffamini
Jaffamini
  • 49 posts
Posted 05 July 2012 - 07:40 PM
Hi can any one help .
loosing water quite quickly over a 10mile run, rad is belowe cores. replaced head gasket.water pump radiator.and rad cap. checked for leaks when hot and running only sign is some around bottom of overflow pipe.but not a rad full.
thanks
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 05 July 2012 - 07:42 PM
Have you bled the air out of the system?
#3 Jaffamini
Jaffamini
  • 49 posts
Posted 05 July 2012 - 07:48 PM
its a job to no as i am filling it up so often
#4 Jaffamini
Jaffamini
  • 49 posts
Posted 05 July 2012 - 07:49 PM
by the way i am mike and i come from essex
#5 Carlos W
Carlos W
  • 10,114 posts
Posted 05 July 2012 - 08:00 PM
Hi Mike,
Did you retorque the head after initial start up?
#6 Jaffamini
Jaffamini
  • 49 posts
Posted 07 July 2012 - 08:52 AM
no not yet.
#7 bmcecosse
bmcecosse
  • 9,699 posts
Posted 07 July 2012 - 01:12 PM
You MUST find out where the water is going - or it's just a guessing game for us. Run the engine at a fast idle - and see where water dribbles out! You MUST retorque the head after the first heat cycle.
#8 Jaffamini
Jaffamini
  • 49 posts
Posted 07 July 2012 - 06:36 PM
with engine hot and running if i lay under car it drips from the overflow pipe. which points to rad cap. but 3 rad caps later no change.
i shall retorgue haed asp
#9 Jaffamini
Jaffamini
  • 49 posts
Posted 11 July 2012 - 07:58 PM
hi all head gasget gone blown between 2 and 3 cylinders. got new one but which way up dose it go. its a b.g.a. make is it tin side down or up.
#10 chrisandsarah
chrisandsarah
  • 746 posts
Posted 11 July 2012 - 09:56 PM
Check behind and around the water pump, maybe a loose jubilee...
#11 Neil-1275
Neil-1275
  • 13 posts
Posted 12 July 2012 - 06:20 PM
check its not leaking out of the side of the water pump too, sometimes these don't leak till the cars been sitting for a while.
#12 Jaffamini
Jaffamini
  • 49 posts
Posted 16 July 2012 - 07:29 PM
hi all put on new head gasket. tin side down (phoned B.G.A.) re torqed after first run. touch wood no leaks yet
thanks for help mike
