Do Mk1's Have Steering Locks?
16 replies to this topic
#1 classicminidriver
classicminidriver
  • 396 posts
Posted 08 July 2012 - 12:05 AM
When did they start putting steering locks on minis?
#2 surfblue63
surfblue63
    TMF fantasy F1 winner 2012
  • 2,539 posts
Posted 08 July 2012 - 01:01 AM
In the early 1970's on the Mk3 and Clubman. Early Mk3 and Clubmans still had the ignition switch mounted in the switch panel. There were some Mk2 models for certain export markets that had steering locks fitted, but none for the UK.
#3 dave-88_123
dave-88_123
  • 302 posts
  • Local Club: jurrasic coast minis
Posted 08 July 2012 - 08:58 AM
i belive it was around 71 they started fitting steering locks
#4 Sheikh Pip
Sheikh Pip
  • 239 posts
  • Local Club: Sutton Coldfield Mini Club
Posted 08 July 2012 - 09:02 AM
Didn't really need steering lock in them days, as there was not many thieving b£$^%&*ds about like there is today, I never even bothered locking my doors back 70's.
#5 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 08 July 2012 - 02:07 PM
It depends where the car was built for - even Mk 1s in Sweden had a steering lock.
#6 classicminidriver
classicminidriver
  • 396 posts
Posted 08 July 2012 - 06:08 PM
Uk built, can you put a steering lock on a mk1 that does'nt have one without changing its looks?
#7 mk1leg
mk1leg
  • 9,343 posts
Posted 08 July 2012 - 06:19 PM
1969 when mk3 came on to production.............. :proud:
#8 Cooperman
  • 23,320 posts
Posted 08 July 2012 - 06:21 PM
Not really as the key is in the centre of the dash panel, not on the steering column. You could fit a Mk.3 steering column a nd re-wire to suit, but it would look very different.
Actually it took about 20 seconds to steal a Mk.1 850. You open the bonnet and put a small coin across the fuses which puts the ignition on, break the door lock by putting a short piece of tube on it and lever down, then get in and press the floor starter button!
#9 classicminidriver
classicminidriver
  • 396 posts
Posted 08 July 2012 - 07:10 PM
can you fit an immobiliser to a mk1 850? can I fit cat 1 alarm/immobiliser
#10 MiniJosh92
MiniJosh92
  • 1,708 posts
Posted 08 July 2012 - 07:27 PM
My mk1 has a steering lock fitted on the original column. It's an old aftermarket addition.
#11 classicminidriver
classicminidriver
  • 396 posts
Posted 08 July 2012 - 07:30 PM
Thanks where do you get them? and it doesn't alter it's original look?
#12 MiniJosh92
MiniJosh92
  • 1,708 posts
Posted 08 July 2012 - 07:37 PM
I doubt you could buy a new one, it was probably added in the 70's. You could probably break it buy leaning on it a bit hard.
#13 classicminidriver
classicminidriver
  • 396 posts
Posted 08 July 2012 - 07:46 PM
does anyone know then if you can fit a Thatcham Cat 1 Alarm/immobiliser + Tracker to a mk1 850?
#14 adam_93rio
adam_93rio
  • 3,271 posts
Posted 08 July 2012 - 07:50 PM
Of course you can, it's jus wiring at the end of the day.
#15 classicminidriver
classicminidriver
  • 396 posts
Posted 08 July 2012 - 07:51 PM
you say that but its not a standard set up...
