Wiring In Spotlights
10 replies to this topic
#1 DavidM
DavidM
    Starting My Mini Up
  • 2 posts
Posted 10 July 2012 - 06:30 PM
Recently bought my first Mini ('94 Mayfair since you asked) and have since discovered that despite two spotlights being present... they're not wired in!
So I'm hoping some of you kind souls could help me with a few queries.
1. Should they be wired in so they act as an additional full beam?
2. Or as fog lights?
Also, is there a place for a switch or would I have to 'modify' the dashboard to mount a switch? Suppose that'd only be applicable if I were to wire them in as fog lights.
#2 firefox
firefox
  • 1,102 posts
  • Local Club: will find one when on the road
Posted 11 July 2012 - 11:10 AM
This will help spots should come on with high beam and go off
sorry wont let me upload file
Edited by firefox, 11 July 2012 - 11:12 AM.
#3 firefox
firefox
  • 1,102 posts
Posted 11 July 2012 - 11:22 AM
http://www.ocoop.com...ipac-wiring.gif
wire 6 from the battery i ran to a 4 way blade fuse box and fused each one separate
the wire to the headlights needs to connect to the blue and white high beam wire
in the loom
Edited by firefox, 11 July 2012 - 11:27 AM.
#4 oliver122
oliver122
  • 1,007 posts
Posted 11 July 2012 - 12:27 PM
take the power from the starter so you dont have to run lots of cables from your battery , will want to take the switch wire from your main beam
#5 mattbeddow
mattbeddow
  • 337 posts
Posted 11 July 2012 - 02:21 PM
It depends on if they are spots or fogs.
If they are fogs the wire them as such, if not then dont.
Spotlights only have part of the lens with a stripe pattern, fogs are all stripes
#6 mattbeddow
mattbeddow
  • 337 posts
Posted 11 July 2012 - 02:23 PM
http://www.accesscon...ghts_wiring.htm
I found this site quite helpful.
The first diagram shows how to wire fogs with a fog switch, just remove the switch and use the high beam wire rather than low for driving lamps
#7 firefox
firefox
  • 1,102 posts
Posted 12 July 2012 - 09:59 AM
With driving lamps you CANNOT put a switch in the circut they need to come on and go off with high beam, fog lights can be switched
well this is the way i understand it
#8 mattbeddow
mattbeddow
  • 337 posts
Posted 12 July 2012 - 01:45 PM
Thats why i said to remove the switch for driving lamps, though i dont see the problem of having a switch, so long as they can still only come on when the highbeam is on
#9 PaddyShepherd
PaddyShepherd
  • 687 posts
  • Local Club: BOGMOG
Posted 12 July 2012 - 02:30 PM
Driving lamps can have a switch, so that they are not always on when the full beam is on.. The switch gets live power when the full beam is on, then the driving lamps are switched from there. So; if you have your full beam on, you can activate the switch and turn the lamps on.. but if you knock your full beam off, the switch becomes dead and so the lamps turn off.
Fog Lights must be switched.
Edited by PaddyShepherd, 12 July 2012 - 02:30 PM.
#10 firefox
firefox
  • 1,102 posts
Posted 12 July 2012 - 07:44 PM
thanks for that boys i understand now, i must have read that you cant have a switch to bring them on without the headlights on full beam, but why fit a switch to keep them off with full beam, if you are setting up the headlights and you dont want the spots on, why not just pull the fuse
#11 PaddyShepherd
PaddyShepherd
  • 687 posts
Posted 12 July 2012 - 10:32 PM
That's also another option I guess, but it's also just a shortcut really, which some people wouldn't like. plus, the fuse on mine is under the bonnet haha.
