Electro-Less Nickel Plating
4 replies to this topic
#1 Jake Didsbury
Jake Didsbury
  • 294 posts
  • Local Club: Barnsley Mini Club
Posted 10 July 2012 - 07:12 PM
Where I work, we refurbish cooling systems for the steel works, this involves sand blasting and nickel plating. We had the idea to try some car parts in our nickel tanks, the process is electro-less nickel plating which is low temperature (below 100 degrees) which means no warpage.
This process is used by us for the steel works and it is also used on off shore oil rigs.
We have the ability to do it very easily and have tanks big enough to drop a subframe in or a front wing etc.
This process gives a nickel coating that has excellent corrosion resistance, gives a surface twice harder than stainless steel and is also self lubricating
We have been testing some samples, we are going to try to etc prime some plated panels to see if they can be painted to
Here are some photos
Attached File  293720_10151021243433966_621615900_n.jpg   26.87K   1 downloads
Attached File  389083_10151021253983966_1690868601_n.jpg   22.79K   6 downloads
The bare metal (just blasted arm just going into the tank)
Attached File  250908_10151021256198966_1327524835_n.jpg   22.05K   3 downloads
In the tank
Attached File  558328_10151021303318966_1097878807_n.jpg   55.93K   10 downloads
Nickel plated cast steel, 40 microns thick, twice harder than stainless steel, highly corrosive resistant and self lubricating
Attached File  580829_10151021302798966_534087256_n.jpg   61.89K   8 downloads
At the moment we are doing trials as to the weld-ability of the plating
Jake
Edited by Jake Didsbury, 11 July 2012 - 04:25 PM.
#2 mini*mad
mini*mad
  • 423 posts
Posted 10 July 2012 - 07:21 PM
hmm very interested in this!
rear subframe would be great!
whole shell would be better;)
#3 Jake Didsbury
Jake Didsbury
  • 294 posts
Posted 10 July 2012 - 07:26 PM
It would your right! If we had a tank to do it im sure we would!
We are currently testing it all at the moment, when we have the 'set in stone' results this will be available
Thank you!
#4 MiniElliott
MiniElliott
  • 378 posts
Posted 10 July 2012 - 10:52 PM
Wouldnt this also polish up to a mirror finish with a bit of effort ?
#5 Jake Didsbury
Jake Didsbury
  • 294 posts
Posted 11 July 2012 - 06:54 AM
Possibly Elliott, we haven't tried that but its something we can try. We blast the stuff first before it goes into the tank and if we blast it with a fine beed it gives a nice finish when plated and we found a coating of about 30-40 microns gives a nice shine on a smooth surface
Jake
Edited by Jake Didsbury, 11 July 2012 - 06:54 AM.
