any help with a rad?
Posted 05 September 2003 - 07:20 PM
ive thort about getting a new rad fitted
this is the link to the rad ive seen
what you think and do you no of anywhere i can get a cheaper one or better else where?
Posted 04 January 2004 - 12:33 AM
because summer is only a cople of months away ish lol
and i want to be ready for it, so how do i make my engine run very well in this hot weather????? because i cant be doing with over heating...
i have a new ish (1 year old) rad fitted at the mo, standard. and a standard thero fitted too. brand new water pump fitted last summer... but any more help would be nice...
i want to run cool this summer.
Posted 05 January 2004 - 08:22 PM
Posted 05 January 2004 - 08:41 PM
cool thats a good idea, does it fit in there between the inner wing and the rad does it???
Posted 05 January 2004 - 10:03 PM
Posted 05 January 2004 - 11:12 PM
Posted 06 January 2004 - 12:25 AM
that im going to try and do it get a fan to try and fit it to the out side of rad between the inner wing and the rad, hopefully it will fit, and if it works that well it will be great...
Posted 06 January 2004 - 04:26 PM
Posted 06 January 2004 - 06:00 PM
sumone told me dat the electric fan on a mk1 astra ia a gud idea, its more like a kit compaired to jus a fan unit, coming with all the parts needed to complete.
I have a front mounted rad on my clubman, i only have one fan on it and its infront of the rad (jus behind the grill, but the bloody thing is constantly overheating. Ive found a new rad off an LDV 2.0 van at work that looks alot like mine (4 core and only £25!!!)
so im gunna put that on, but am i better off haveing 2 fans and having one infront of the rad and one behind sucking???
cheers all
Posted 06 January 2004 - 08:21 PM
Posted 06 January 2004 - 08:30 PM
If your gonna go with the 2 fans, I'd go with them both on the inside suckin, drawin the cold outside air through the rad, instead of blowin it against it (probly find alot of the cold air just bounces off).
Posted 06 January 2004 - 08:44 PM
Posted 07 January 2004 - 06:37 PM
i have a oil cooler but no pipe's tucked away....
are they realy woth adding???
Posted 07 January 2004 - 09:42 PM
Go to your local hydrollics suplier and get some hoses made up, they are not expensive.
Posted 12 January 2004 - 10:17 AM
