Hazard Lights - Kit Or Diy?
5 replies to this topic
#1 hipshaker
hipshaker
  • 12 posts
Posted 14 July 2012 - 04:33 PM
Hi
I want to get some hazard lights on my 1966 van ....... and saw the kit below on the moss site. is this the best/easiest way of doing it ...... or can it be done easily with separate bits?
http://www.moss-euro...teIndexID=13162
all advice appreciated!
#2 Old Bob
Old Bob
    TMF Menber Passed On R.I,P
  • 825 posts
Posted 14 July 2012 - 04:50 PM
That certainly looks the easiest way of doing the job but it really isn't that difficult so you could buy the separate parts and save a little. Convenience or cost?
Bob
#3 The Principal
The Principal
  • 765 posts
Posted 15 July 2012 - 06:19 AM
Its an easy job to wire a new Hazard switch into the indicator circuit, in terms of cost and convenience i'd stick with the moss kit it also has a retro feel to it. The alternative is a hazard switch from a later car which means changing the switch panel and the other switches or a custom made mounting bracket.
You've probably worked this out but your need an additional flasher unit.
#4 pdaykin
pdaykin
  • 587 posts
Posted 15 July 2012 - 08:26 AM
I took the DIY method myself - purely because i was adding other stuff too.
That kit was going to be my alternative.
At the time, I thought that the kit looked expensive. But by the time you buy wire, a bracket, tell-tale light, relay, fuse and switch the costs mount up if you want it to look period. Modern looking switches and relays are ten-a-penny. But I thought they would look odd on my 64 and 67
#5 hipshaker
hipshaker
  • 12 posts
Posted 15 July 2012 - 09:06 AM
thanks all ...... i thought the kit looked comprehensive. wondered whether they're were any better switches and stuff about. i also need to add a reverse light too .... and was thinking of this little switch panel for both (will leave a spare switch):
also want to fit a cigarette lighter for sat nav.
#6 hipshaker
hipshaker
  • 12 posts
Posted 20 July 2012 - 06:17 PM
well ..... i bought the switches above and very nice they are too!
does anyone know exactly what i need to go the DIY route? is there anywhere that sells a diy type kit?
