Restoring
4 replies to this topic
#1 minimad91
minimad91
  • 188 posts
Posted 14 July 2012 - 07:42 PM
Hello I have just taken my Mini off the road I need to remove the rear subframe replace nearside sills and and rear subframe mounting panel at the same time I'd like to remove the engine and refurb! My question is how is the best way to do so I would also like to be able to work on the bottom of the car???
#2 stretters
stretters
  • 71 posts
  • Local Club: Ipswich MOC, AMC, CMC, MCR.
Posted 14 July 2012 - 08:14 PM
If your going to remove the front and rear sub-frames your best bet will be to take out the interior and all the glass then roll it on the opposite side you wish to work onto a single/double mattress. Obviously an old unused one on the way to the dump! lol
Also drain the fuel tank and remove along with the battery first, get a length of fuel hose to join up the outlet pipe with the breather/return on the tank to avoid the fumes leaking out......
You can disconnect the front subframe and still leave the engine in situ by lifting the body over the top.
Here's mine stripped in a few hours although all the work on this shell is above the sills....
Attached File  stripped 20.02.12 (3).JPG   87.02K   12 downloads Attached File  stripped 20.02.12 (5).JPG   62.22K   12 downloads
Good luck. ;-)
Edited by stretters, 14 July 2012 - 08:20 PM.
#3 sledgehammer
sledgehammer
  • 3,129 posts
Posted 14 July 2012 - 08:15 PM
You can mount on a spit - if the engine / gearbox is out (drain fuel tank as well)
or roll it onto the side on a mattress (door mirror removed & door handle padded)
prop it safely if you do
#4 bmcecosse
bmcecosse
  • 9,699 posts
Posted 14 July 2012 - 08:39 PM
My advice - just do one thing at a time - or high risk of a 'failed project' post 6 months down the line............
#5 minimad91
minimad91
  • 188 posts
Posted 14 July 2012 - 09:19 PM
It's going back on the road as its my only car lol and I refuse to sell it lol needs bits done but focusing on sills first as thats the major bit!!
