Referbished Mk2 Fiesta Calipers And Carriers
19 replies to this topic
#1 bradsarcher
bradsarcher
  • 117 posts
Posted 17 July 2012 - 01:39 PM
never used since bigg red calipers did the referb selling due to change of plan
£70 ono
based in Windsor or somerset
#2 daveydavey
daveydavey
  • 43 posts
Posted 17 July 2012 - 09:21 PM
hi
do these have to fit onto hubs that have been modified?
#3 Sam Walters
Sam Walters
  • 2,765 posts
Posted 17 July 2012 - 09:47 PM
Davey, the hubs have to be drilled out to 10.5mm. But it wouldnt be to hard to put a helecoil back in afterwards if you wanted to.
#4 daveydavey
daveydavey
  • 43 posts
Posted 17 July 2012 - 10:16 PM
cheers Sam
still a little confused
i have a set of hubs that have supposed to have been adapted for fiesta brakes...so are these calipers what i need?
and is this set up better than a metro 4 pot or not?
#5 bradsarcher
bradsarcher
  • 117 posts
Posted 17 July 2012 - 10:38 PM
Hubs need to be drilled and discs milled to 7.9 to run 10" wheels also custom hoses.
#6 daveydavey
daveydavey
  • 43 posts
Posted 17 July 2012 - 10:47 PM
more confused now
the hubs i have have a marking of "BTA 188 RH" and "BTA 187 LH" which i presume is left and right hand?
the left hand one also has a marking which looks like "L EE 8 16.G.90
any ideas?
#7 lapider
lapider
  • 473 posts
  • Local Club: cardiff mini club
Posted 18 July 2012 - 12:29 AM
i dont have experience with fiesta callipers but i think what they are saying is that the brake calliper mounting stud pattern on the standard mini hub and the stud pattern on the fiesta callipers are the same. but the sizes of bolt used to hold the calliper to the hub are bigger on the fiesta, therefore the holes are widened and thread re tapped so that the callipers can be bolted to the hub.
when they were talking about machining down the disks they were referring to the fact that the two standard disk sizes produced for minis were 7.5 and 8.4 meaning that you would have to put the 8.4 disk in a lathe and machine the height down to 7.9. alternatively companies like mini spares and mini sport sell 7.9 disks for there custom callipers which may fit.
as i said i dont have experience in these callipers so if anyone could confirm or contradict what ive said.
#8 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 18 July 2012 - 02:49 PM
You'll be needing metro vented disc drive flanges to fit these correctly also.
Minispares offer a version of these:
Edited by Skortchio, 18 July 2012 - 02:49 PM.
#9 Sam Walters
Sam Walters
  • 2,765 posts
Posted 18 July 2012 - 04:44 PM
Davey, watch that.
#10 nomis
nomis
  • 261 posts
Posted 18 July 2012 - 04:55 PM
I have a pair of used flanges if you need them - PM for details or see my ad futher down page
#11 daveydavey
daveydavey
  • 43 posts
Posted 18 July 2012 - 08:50 PM
so am i right in thinking i have fiesta hubs and i need metro turbo flange and disk?....or a metro flange and disk that could be turned down to 7.9 for a 10" mini wheel?
#12 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 18 July 2012 - 09:01 PM
Mini disc, turned down to 7.9".
Metro flange.
Mini hub drilled out.
Fiesta calipers.
Brake lines.
#13 daveydavey
daveydavey
  • 43 posts
Posted 18 July 2012 - 10:03 PM
lol....this gets more confussing by the minute
so.....from what i think i have....which is fiesta hubs (which i believe to have been modified.....if thats what is needed for a mini set up).... what else do i need?
just to add more confusion!!!!.....i have 2 sets of metro 4 pots.......
so............are the fiesta 2 pots better than the metro 4 pots?.......and if so...what else do i need to complete the fiesta conversion?....all i have is the fiesta converted hubs......any help will be appreciated.......!!!!!!!....just thinking about getting everything re-ferbbed then selling and gone with a standard buy off the shelf 4 pot......
#14 daveydavey
daveydavey
  • 43 posts
Posted 18 July 2012 - 10:04 PM
by the way the fiesta hubs look mint
#15 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 18 July 2012 - 10:20 PM
The point of the fiesta conversion was an at the time, cheap route to being able to run 10" wheels, the upshot being the brakes were pretty good.
Metro 4 pots, to my understanding won't fit under 10" wheels.
