Miglia Arches Question :)
16 replies to this topic
#1 Hegnirst
Hegnirst
  • 3,496 posts
  • Local Club: Hilltop Minis
Posted 22 July 2012 - 09:01 AM
hi!
just having a ponder, theres too different sizes of miglia arches, which one are they?
and im thinking of having them on 6x10 mambas (the JBW kind) they have a very big offset and im wondering how much i would have to cut the arches by as there is to sizes apparently and im not to fussed about them being inside the arches, as i can create a better 'ropped' looking :)
thankyou guys! i know similar questions to this have been asked before, i have done my research before hand :)
thanks!
#2 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 22 July 2012 - 10:33 AM
I bought some 'standard' size Miggies from ABS recently, they're about 4" wide but the body edge isn't finished so some will be lost making it match your car.
The extra wide ones are *******in' huge!
#3 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 22 July 2012 - 11:09 AM
The arches on miglia cars are designed to over-arch the wheels slightly. so unless your wanting a bit of poke, will more than likely have to chop a fair bit off the back edges
#4 clivemk1mini
clivemk1mini
  • 1,064 posts
Posted 22 July 2012 - 10:28 PM
I have extra wide miglias they are designed to cover 7" wide wheels
#5 Hegnirst
Hegnirst
  • 3,496 posts
Posted 26 July 2012 - 10:43 PM
im so lost in what arches to choose :/
#6 Hegnirst
Hegnirst
  • 3,496 posts
Posted 26 July 2012 - 10:44 PM
im not worried about the poke as i think i would like them hid under neath :P
#7 Hegnirst
Hegnirst
  • 3,496 posts
Posted 26 July 2012 - 10:45 PM
soooooo stuck! i dont know what to do, i dont think my wheels are wide enough for them :/
they do have a big offset but im unsure without holding some up to it. :'(
#8 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 26 July 2012 - 10:51 PM
Is the wheel on the car? If so, then just put a tape measure against the wing under the side repeater and see how wide your wheel sticks out.
Miggies can be trimmed as narrow as needed, alternatively you could space the wheels. Handling wise, trimming arches is a better bet as spacers diminish it the wider you get. And it's less to buy but if you have to have the fat wheel look then spacers may be your answer, with Miggies of course ;-)
#9 Oxford
Oxford
  • 26 posts
Posted 27 July 2012 - 06:33 AM
I've just bought some of these as well, how do they fit to the car? Heard of people making brackets etc. for them.
#10 mike.
mike.
  • 6,176 posts
Posted 27 July 2012 - 07:59 AM
You need some L brackets for them. Rivet or bond them to the arch and then bolt/screw to the car.
#11 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 27 July 2012 - 09:47 AM
Once you've trimmed them to shape and size, as Mike says you need to make your own bracketry.
I bought some of this:
http://www.ebay.co.uk/itm/150337202233
and some of these:
http://www.ebay.co.uk/itm/390421008822
for the job.
#12 mike.
mike.
  • 6,176 posts
Posted 27 July 2012 - 11:07 AM
Those L brackets look ideal!
I paid about £40 for a fitting kit from minispeed - Worst thing for the job.
Rivets were too short and had exact amount so you mess one up and you've got go and buy more, the brackets were super flimsy and got stretched by the rivet rather than held in place by it. The bolts and nuts were ok, but not £40 worth.
For cheap rivets and stainless nyloc nuts and bolts, look at screwfix. They may sell L brackets too.
#13 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 27 July 2012 - 11:42 AM
I looked at the fitting kit too, decided I like the idea of removing the arches if needed, hence the rivnuts and the angle bar is half a meter so enough for all the arches with 5 brackets per arch - okay for a fiver!
Edited by Skortchio, 27 July 2012 - 11:44 AM.
#14 Oxford
Oxford
  • 26 posts
Posted 27 July 2012 - 06:09 PM
Huddersfield Minis do a set for 12 quid which are designed for the Miglia arches :proud:
#15 Evoman666
Evoman666
  • 20 posts
Posted 10 August 2012 - 12:09 PM
So are these arches standard Miglia's
http://www.ebay.co.u...=item1e702f1e44
