This has probably been covered but I can't find anything, I am ready to paint my mini which has a few patches of surface rust, am I right in thinking if I sand/grind the spots back to bare metal, paint on some krust with a brush, wait 3 hours (as it says on the krust packet) then prime, colour then lacquer everything will be good! Thanks
Getting Rid Of Surface Rust
minipiglet1
, Jul 22 2012 09:26 PM
7 replies to this topic
Posted 22 July 2012 - 09:26 PM
Posted 22 July 2012 - 09:31 PM
Yes and no.
Providing it is only light surface rust then yes it should work. If its pitted at all then you may have problems in which case you may have to carry out local repairs ie cutting the rust out and replacing with fresh metal
If you have access to a spot blaster then this will work well for both. The one thing you must remember with mini panels are that they are formed from thin metal so removing a lot will seriously weaken it.
Posted 22 July 2012 - 11:08 PM
If you sand the patches down as much as you can going through stages of sand paper. e.g 80, 180, 600 (wet and dry) 800 (wet and dry), this should help take it down.
But as above if it is pitted it will need to be shot blasted to get it out or cut the sections out that have pitted.
If pitted you could try using filler then smoothing it down the the same shape of the metal, but the rust will come back over time.
Posted 23 July 2012 - 10:57 AM
So the rust will come back through even if I put krust on first?
Posted 23 July 2012 - 11:12 AM
If it's only light pitting you could use POR15 Prep & Ready ( http://www.frost.co....eady-946ml.html ) I must admit I was sceptical about something that actually removes rust altogether, but was pleasantly surprised when I first bought this. It actually works, you just need to keep the area wet with it for a while (can take up to half an hour) and work it with a small stiff brush and it literally dissolves the rust away back to clean metal. Then just clean the area and I'd give it a coat of red oxide primer then ready for the proper paint.
Posted 23 July 2012 - 11:47 AM
No such thing as surface rust on a mini
Posted 23 July 2012 - 12:58 PM
Yes there is, unlikely I know but it does happened for instance under the seam strips where there is no factory paint, I personally blasted my inner wings on a previous mini I had which were covered in surface rust. One coat of zinc rich primer and a couple of coats with a rattle can, 10 years latter the passenger side is still perfect, the other drivers side is just starting to show signs of rust again
David
Posted 23 July 2012 - 08:36 PM
Surface rust. Should be treated straight away. I left my surafce rust on my boot lid for a little too long and when the time came to paint it. i found a little hole :S
Hallam
Hallam
