BBG amp,
5 replies to this topic
#1 screech
screech
  • 3,136 posts
  • Local Club: Bognor rock ya mini & WSMOC
Posted 15 March 2006 - 05:15 PM
today my amp packed up on way home from work, not very happy as its meant to go back in the mini soon, its got power, the power light is on, the protection light is off,but the blue neon that lights up when it is on is not on, both fuses are fine.
its a BBG ryval series 4 ch.
Does anyone know any common faults with these? Gotta get it looked at!
Poo Poo.
#2 THedooBZ
THedooBZ
  • 887 posts
Posted 15 March 2006 - 05:30 PM
my mate had a similar problem, although a different amp, its was down to a dodgy earth, so first thing is check all of the connections.
check the rca leads from the head unit that they havent come loose.
can u try it on someone elses stereo???
u said that the power light is on, but a blue neon that lights up when its on isnt, do you mean it has 2 power lights????
#3 screech
screech
  • 3,136 posts
Posted 15 March 2006 - 05:33 PM
all connections are fine, the blue neon thing is just for show, lights up the nice logo on front that all.
#4 THedooBZ
THedooBZ
  • 887 posts
Posted 15 March 2006 - 05:51 PM
well somethings gone pop inside then, without having it tested properly you just wont know to be honest.
the only thing i can suggest is to check if the neon has actually blown with a multimeter by doing a continuity test, if so you could find the circuit protection will have shut the amp off.
#5 screech
screech
  • 3,136 posts
Posted 15 March 2006 - 06:06 PM
going to go to huets tomoz to get it tested, hopefully its repairable.
#6 screech
screech
  • 3,136 posts
Posted 25 March 2006 - 07:41 PM
YAY, had it repaired!
2 popped diode packs!
