Smiths Clocks
Posted 24 July 2012 - 07:32 AM
Thanks, Matt
Posted 24 July 2012 - 07:37 AM
Your car is negative earth, so you should have no problems there.
Posted 24 July 2012 - 09:14 AM
Posted 24 July 2012 - 12:03 PM
Posted 24 July 2012 - 12:55 PM
The other gauges are not simple plug and play. First, the later Smiths gauges (post 1960s) are not polarity sensitive so there is no worry there. They can be wired either way. HOWEVER, they are NOT powered directly by 12V. You MUST add a voltage stabilizer to the wiring to supply the gauges with a controlled 10V. You will find sources on eBay selling generic, solid-state voltage regulators/stabilizers for gauges. They will be suitable.
Apart from that warning, follow the wiring diagrams for the donor car you got the gauges from to install the new/old gauges in your car.
Posted 24 July 2012 - 01:01 PM
Use the search feature on here to learn from old threads about matching the turns-per-mile out of the gearbox to a particular speedometer. There are many variables that affect whether a speedometer will be compatible with your car's gearing and tire size.
By Gauges do you mean oil pressure and water temp and stuff like that because I have volt stabilisers for them it's just the speedo not working but I need a new cable anyway so I wasn't sure what to get and the rev counter not working as the terminals on the back are different the fuel gauge has a volt regulator on the back of the clocks as standard
Posted 24 July 2012 - 01:12 PM
You said your car had the Nippon-Seiki gauges. Those do not have the voltage stabilizer where you can access it. The stabilizer is built into one of the two gauges but I don't remember which. I assume when you reference the stabilizer on the "back" you are talking about there being a voltage stabilizer on the back of your new/old Smiths donor gauges. If that is what you meant, then yes, you have the stabilizer you need for the new gauges.
There are different types of Smiths tachometers. Look on the gauge face for the letters RVI or RVC and let us know which you have. Also let us know if you have electronic ignition. Once we know the type of tachometer and your ignition type we can discuss tachometer wiring.
Early Smiths speedometers had a male thread on the back for an M12x1 nut on the end of the cable. Sometime in the early to mid 1970s Smiths appears to have changed to a clip-on cable type. The gearbox end of the speedo cables is the same and threaded 3/4-26. If you are planning on using an early speedo in a later car you need to buy the early speedometer cable to match. All that is moot if your turns-per-mile number on the new speedometer do not match what is right for your car's gearing and tire size. Yes, you can have the speedometer re-calibrated/rebuilt to match your car's gearing but it is expensive and finding the "right" speedometer is likely to be more cost effective.
Posted 24 July 2012 - 01:36 PM
Posted 24 July 2012 - 08:11 PM
RVI tachs seldom work with electronic ignitions. They are an older design wired in series with current flowing to/through the ignition coil and they monitor current pulses. You will be much happier in the long run looking for a later Smiths RVC type tach instead. RVC tachs are more or less similar to modern tachometers. They use a single sense wire connection to coil (-) and they "count" voltage pulses. Those are compatible with electronic ignitions.
Posted 25 July 2012 - 09:25 AM
Posted 25 July 2012 - 10:17 AM
Posted 25 July 2012 - 11:51 AM
Doz, congratulations. You are the second person I know of who has found an RVI that works with electronic ignitions.
Posted 25 July 2012 - 11:55 AM
Posted 25 July 2012 - 12:20 PM
