Rs Turbo Seats
jonny95
, Jul 24 2012 10:26 PM
9 replies to this topic
Posted 24 July 2012 - 10:26 PM
Does anyone have rs turbo or similar recaros fitted in there mini??
If so, how well do they fit and do they flip forward enough to allow access to the back seats??
Cheers.
Cheers.
Posted 25 July 2012 - 01:46 AM
Hi,
I have seen Recaro seats fitted in minis a few times and by the looks of some of them they looked like rs turbo seats so it is possible, not sure about the space you would have though! i would like to know that myself actually because i am considering getting them seats too! :)
recaros -
http://carphotos.car...40004_large.jpg
http://www.solenoidv...ta/SDC11136.JPG
theres a guy on the 16v club who has got rs turbo seats - http://www.16vminicl...ead.php?t=15808
recaros -
Posted 25 July 2012 - 06:36 AM
I fitted xr3i seats once and they were ok. Things to consider are the overall height of the seat base when mounted and the height of the back. I know they tip over but not sure if the headrest hits the screen early. They are a similar if not identical seat to the recoaro GTB (i think).
You can get a dark grey version from escorts and a light grey and then an almost charcoal/black one out the fiesta. But they command good money and are quite ofter worn out. Drivers bolster and the seat bases themself. Also check underneath as the frames can crack. Just from experience (mainly a ford fan, but mad on minis).
Mine in my last xr2
And the car
Mine in my last xr2
And the car
Posted 25 July 2012 - 09:48 AM
yes I have them:
I modified some cobra sub frames to make them fit, but there not ideal. When its off the road I plan to make something from secure.
Posted 25 July 2012 - 10:13 AM
i also have them great fit
Posted 25 July 2012 - 11:41 AM
I wouldn't say great, but they do fit. If you have them right at the back of their travel it rubs on the rear bins, so has worn some of the vinyl on the outer back edge off, also they can sit quite high on cobra subframes I had to cut them down allot. I wanted to try and make my own subframe that would move it over slightly and sit lower.
Posted 25 July 2012 - 12:55 PM
whats it like height wise, can they bflip forward or do they hit the roof or windscreen??
Posted 25 July 2012 - 12:58 PM
they don't hit the roof but they will hit the windscreen. But at that point there is enough room for people to squeeze in the back (as tested by my 6' + friend
Posted 25 July 2012 - 09:47 PM
They should fit, I have some recaros from a 2.8 injection capri going in mine in the next fortnight and so far they look like they should fit ok.
Posted 25 July 2012 - 10:16 PM
Using subframes from other seats is ludicrous, there never gonna fit like they should! Mine are amazing,and touch the rear seat, home built subframes ftw.
