Superfins
Posted 25 July 2012 - 07:34 PM
Posted 25 July 2012 - 07:56 PM
The cheap ones really are crap, but the genuine much better. (Minisports 'own' are actually just the cheapo ones that most places sell for half the price!!!).
Posted 25 July 2012 - 07:59 PM
I could be wrong but that what I thought, the quality of build should be similar.
Edited by H.M.M., 25 July 2012 - 08:00 PM.
Posted 25 July 2012 - 08:03 PM
Posted 25 July 2012 - 08:06 PM
I think the only difference between minifins and super minifins are that the super minifins have (so called) cooling fins on and the standard are similar to the cooper ones (look like a standard drum with a space attached)
No, they both look pretty much identicle.. The only difference being, the cheap ones have a few extra fins.
I will also add that I happened to come accross one of the non-genuine ones that had cracked!.. Up until this point I was going to buy some for my mini.
Posted 25 July 2012 - 08:48 PM
Posted 25 July 2012 - 08:50 PM
Posted 25 July 2012 - 08:52 PM
Posted 25 July 2012 - 08:59 PM
But you see the good ones could crack, who knows?, unless you work day in day out on minis how can you Judge one against the other, only done 3k with mine but still look ok because I've just had them off cleaned and adjusted them.. Alan
You're correct, and I agrea, but the only experience of them braking is the cheap ones.. Hence the reason I'd go for the expensive ones which look much better made.
Posted 25 July 2012 - 09:40 PM
Posted 25 July 2012 - 10:12 PM
Posted 26 July 2012 - 06:33 PM
Posted 26 July 2012 - 07:00 PM
I've not actually used them, but have owned several pairs..
No they are not, they are made in house in Padiham........
I'd get your facts right before making relating a quality product to a chinese copy equivalent.
Edited by Midas Mk1, 26 July 2012 - 07:01 PM.
Posted 26 July 2012 - 07:32 PM
Can I ask how you know this?
Its what I've read on here, and put them next to each other they look exactly the same with the same differences from the genuine ones.
They even both had the same scratch marks on the inside- presumably part od the manufacturing process?
Posted 26 July 2012 - 08:08 PM
