Inertia To Pre/engaged Starter
Posted 25 July 2012 - 09:07 PM
Posted 25 July 2012 - 09:16 PM
Posted 26 July 2012 - 03:28 AM
Posted 26 July 2012 - 08:32 AM
You could use your wing solenoid to do this.
Keep the wiring standard on the wing solenoid , but do keep the starter cable on the battery terminal like you have it.
The terminal on the wing solenoid that was the starter terminal run a wire from that to the large spade on the new starter (its the top one if I recall right)
Edited by lrostoke, 26 July 2012 - 08:33 AM.
Posted 26 July 2012 - 12:23 PM
no to the small one is that where i have gone wrong ?
As below the BIG spade
sorry as above ha ha ha
Edited by firefox, 26 July 2012 - 12:23 PM.
Posted 26 July 2012 - 01:44 PM
Posted 26 July 2012 - 02:21 PM
ok will try that will it blow ignition if wrong ?
No
Posted 26 July 2012 - 02:29 PM
Posted 26 July 2012 - 04:54 PM
Posted 26 July 2012 - 05:02 PM
i have now got the engine to turn over she coughs a bit but will not start got good spark at plugs good fuel flow still scrachimg head
Engine type , fuel type carb spi mpi give us a clue
Posted 26 July 2012 - 05:41 PM
Posted 26 July 2012 - 05:45 PM
ht leads are they on right be suprised how many get it wrong and takes a double take to realise its wrong
No 1 plug nearest radiator
On the dizzy cap No 1 lead is normally top right
plugs
4 - 3 - 2 - 1
dizzy
3 - 1
4 - 2
above is order on engine and dizzy
Posted 26 July 2012 - 05:48 PM
Posted 26 July 2012 - 05:51 PM
check all the simple stuff
plugs
4 - 3 - 2 - 1
dizzy
3 - 1
4 - 2
That is if the dizy drive is not 180 out
Posted 26 July 2012 - 05:54 PM
